Home Theater Audio Advice - RT 400 ??
skeedracer
skeedracer Posts: 2
edited September 2005 in Speakers
I have 12 yr old RT400's as my stereo speakers. I've been satisfied with them. I'm going to get a home theater set up - probably a 6.1. Would you suggest I use these as my fronts? Or would I be better off getting a set of current day speakers all matched to each other? If they are worth using, which speakers should I match them with in today's Polk line at the approx same audio quality?
Brad
Post edited by skeedracer on
  • amulford
    amulford Posts: 5,020
    Your not going to find anything made now that'll match.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    The 400's are GREAT speakers. They were one of the two Polk speakers I fell in love with, popped my Polk cherry if you will. The RT400, and the RT7.
    Look for soft/polymer dome vintage Polk speakers to match. A CS200, and RT3 would be the PERFECT match. On that note, the new Monitor and RTi series won't be TOO far off either.
    Nutshelled, you can certainly build a GREAT home theater rig around the 400's, don't put them out to pasture yet - and if you decide to - give me a shout.
    Cheers,
    Russ
  • skeedracer
    skeedracer Posts: 2
    Thanks guys. Good to know I'm on solid ground.
    Brad
