Donner Haus DH-10
janmike
janmike Posts: 6,146
Has anyone heard or had experience with this sub.
Donner Haus DH-10
Here are some listing specs: (Which does not say a lot)
Rated Power – 400 Watt
Peak Frequency Response – 45-150 Hz
Power Consumption – 120V AC 60Hz 200 VA
Dimensions : mm 425h x 316w x 415d inches 16.7h x 12.5w x 16.3d
Weight - 16.7 kg/36.7 lb
Amplifier Type – High efficiency, high output Class “D” amplifier.
Amplifier Features – High Dynamic power design.
LFE input. Phase switch.
Crossover control.
Driver compensated EQ circuitry.
Automatic turn on/off.
Low Pass Crossover – Precision Variable Electronic Crossover 50-150Hz
High Pass Crossover – Passive Filter, 6db/Octave Inputs – Line/Low Level – Mono or Stereo RCA Type High Level – Binding Posts
Maximum Input – 150 Watt/Channel @ 8ohm (HIGH LEVEL)
Protection – Intelligent Overdrive Protection Circuit (Internal Fuse 1.25 A SloBlo type)
Finish – Cabinet (Black Sandex)
Thanks Guys.
Michael ;)
NORTH of 60°
