RTi4's vs. RTi6's?
tdogroeder
tdogroeder Posts: 53
edited December 2011 in Speakers
Is there much of a difference in these other than the RTi6's using a bigger woofer, and cabinet size?
Yamaha RXV-757
JM-Lab Focal Cobalt 816 S's, JM-LabFocal Cobalt CC 800 S, FXi3's, RT15's & PSW 303
Post edited by tdogroeder on
  • sucks2beme
    sucks2beme Posts: 5,693
    edited September 2005
    Bigger is better in this case. Got both. The RTI6 sounds better all the way around.
  • Willow
    Willow Posts: 11,297
    It can be providing the person buying realizes just how big the 6s are. They both sound great with a sub. I used the 4 as mains and have no complaints. Now they serve as rears and are great.
  • tdogroeder
    I have a Yamaha RX-V757 reciever 7.1 (100watts) per channel, would that be enough to run those, CSi5's and FXi5's and still sound good?
    Yamaha RXV-757
  • schwarcw
    schwarcw Posts: 7,360
    I have a pair of RTi6s that I use as surrounds. They sound great! They are big, about 14" deep. Nice bass response, but you'll need a subwoofer. I use a CSi40 for the center and SDAs for the fronts. I'm satisfied. The RTi4s are smaller and have comparable sound, a little less bass but not bright. If your using a sub you can't go wrong with either.
    Carl
  • Willow
    Yes, I have a 540 and it runs my rti8s csi3 and rti4. Its plenty loud and clear for my room, for now.
  • aaharvel
    aaharvel Posts: 4,489
    i compared both before i bought. In my opinon the imaging was better with the 4's; the midrange slightly more focused with it's 5.25" driver. The tweeter sounds nearly identical- both are built great. I liked the dimensions of the rti4 better. If you don't like LOUD music, aren't in a huge room and have a subwoofer crossed over at 80 hz I say save the $120 and get the 4's. Regardless, you Can't go wrong with either. Both are light years ahead of the Monitor line imo.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • MacLeod
    MacLeod Posts: 14,358
    Plus the 4's run about $250! Very good price for this level of performance and quality.
  • dkg999
    dkg999 Posts: 5,647
    I was driving Rti6's as mains and Rti4's as surrounds, and a CSi5 center with a Yamaha HTR-5660 receiver. I did alright. These both are great HT speakers! I did pick up a used Adcom 7605 5 ch. amp, and used with these same speakers and the pre-outs from the HTR-5660, this system rocks!
    DKG999
  • cmy330go
    cmy330go Posts: 2,341
    I also had a set of each of these speakers at one time. I would have to agree with Andrew. The 4s seemed a little more transparent. True they would not play as loud as the 6s, and lacked a little on the low end, but over all I actually prefered the 4s. I also felt that the 6s were slightly on the bright side and prefered the warmer sound of the 4s. Just my $.02.
    HT
    Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
    2 CH
    Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
  • pyrocyborg
    pyrocyborg Posts: 524
    /Necrothread
    Sorry to bring this back from the dead but I could have a deal on a pair of brand new RTi6. I currently own RTi4 as front speaker and would like to know how thoses both compares to each other. Some people says RTi6 are fuller, warmer, while others claim it's in fact a tad brighter than it's little brother... On my system, RTi4 are bright, so I think I couldn't stand anything brighter unless I swap my receiver for a warmer one (currently have a low-end Yamaha).
    I know the best thing would be to test and compare both, which I think I'll do, but I would like to have your opinion on the matter.
    Thanks a lot everyone!
    Speakers: Polk Audio LSiM 705, LSiM 703, LSiM 704c
    Receiver: Denon X3500H
