My CSi5 Needs Help!!!!!
Vgamer4550
Hey ya'all.......I think my center channel needs a little help and I am not quite sure what I am doing wrong.
I picked myself up a Polk CSi5 Center Channel speaker and I am currently powering that with a Denon 3805 Reciever. I also picked myself up a Denon DVD-1600 DVD player (awsome player but not sure if that really has anything to do with my problem). Now I know I am doing the speaker an injustice by not running a seperate amp to it but budget restraints are making me hold off on that for a bit. I will be purchasing an Outlaw M200 Monoblock Amp just for the CSi5 as soon as I am able to.
Now here is my problem, while watching movies I am having a heck of a time hearing the dialogue from 5.1 soundtracks. I have referenced my setup and I have the center kicked up about 2dbs higher then the other speakers in my setup and the Reciever is setup to crossover at about 80hrz. I still have to kick up the volume on most soundtracks to hear what they are saying and then turn it down again when the action starts.
This might be a stupid problem but its one that I cant seem to shake and one I thought the CSi5 might be able to help me with. If you guys have any opinions please lend me your two cents. I would appreciate it greatly, thanks.
What's the rest of your setup?
is the center angeled up or down ( down if its above your TV, up if its below) - you want the tweeter firing at ear level.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
The Rest of my setup consists of 4 Polk FXi3s for surround (its a 7.1 setup), 2 Old, Giant Yamaha Speakers for the fronts and a 10" Sony Subwoofer that needs to be replace (this is all still a work in progress).
As for how the Center is placed, it is sitting on top of a 55" Mitsubishi RPTV, WS-55515. It is pointing straight out at the center of the room right where I usually sit, just above ear level I should think.
I do have the Denon currently setup so that if sound is sent to the surrounds (and its not a DTS ES or Dolby EX soundtrack) that the surround gets output through all four surrounds instead of just the surround sides. I did this to make use of the extra speakers and because I cant setup the surrounds the way they really need to be set up do to room constraints.
Need anymore infor to help just let me know. -
This could be the problem:
"2 Old, Giant Yamaha Speakers for the fronts "
You've mated the Csi5 with fronts that have a different tonal quality and probably different efficiencies. -
I am looking into Purchasing a set of RTi10s eventually and then an HSU VTF-3 MKII sub to complete the setup. If the dough comes in I may end up with the RTi12s but I personally did not see that much of an improvment over the 10s to pay an extra 2-400 bucks for them.
The Yamahas aside, is there anything else I might be able to do to improve the sound from the center. -
Put some rubber door stops under the center.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I also have the CSi5 and a Denon 3803...I have also had problems with dialog from the center...have calibrated hot,didn't seem to help much.
I added 200 wpc to the center and it came around using the Denon as a pre/pro.
Must be Denons nature to be a little weak on center output,it's now just powering our side/rear surrounds and is doing very well... -
Hey Mike, That sounds pretty much how I want to get my setup to get to at some point in time. I want to get a Pair of RTi10s, get a Crown XLS-402 Amp to power them and then the Outlaw M200 Monoblock for the center, that way I take most of the pressure off the reciever and let it handle the surrounds only.
Once you set it up that way did it seem to help things out a bit more with center channel sound. -
I'll have to try and find an amp for my CSi5. I'm having the same problem, I have an older Denon and it's hard to hear the dialogue as well. Hopefully an amp will solve the problem.
Regards,
ScottSYSTEM
HDTV ..........Sony KP-57WV600
CD / DVD......Sony DVP-C675D
AVR ............Denon 2801
MAINS .........Polk RTi8
CENTER .......Polk CSi5
Surrounds ....Polk FXi3
Sub ............Polk PSW-250
Cables.........Zebra Cables -
My Onkyo 700 is pushin the Csi5 just fine.
Hey Vgamer, since you are going to get a nice sub to handle your frequencies below 80Hz, save some money and go with the Rti8's for the fronts. -
Vgamer4550 wrote:Hey Mike, That sounds pretty much how I want to get my setup to get to at some point in time. I want to get a Pair of RTi10s, get a Crown XLS-402 Amp to power them and then the Outlaw M200 Monoblock for the center, that way I take most of the pressure off the reciever and let it handle the surrounds only.
[Once you set it up that way did it seem to help things out a bit more with center channel sound.]
Yes,adding the external amps made a difference on the output levels of the center/mains...The Denon has a "laid back" sound to it,seems to be in their nature.
This is not a bad quality,especially with music...but for Home Theater,it just doesn't have that "in your face" sound to it...
I would opt for a good used 3-channel amp to power your mains/center...forget the Pro-amp for your mains...that, or,pick up 3 monos from Outlaw...
Either way,more power is a good thing.... -
You mentioned you "referenced" the system...maybe you already did this but I'll ask anyway....have you used a sound level meter to calibrate? I have a Denon 3803 powering CSi5 and RTi8's in the front stage and dialogue comes crisp and clear from the center....._________________________________________________
try using the dynamic range compression feature
Ya, I used a sound level meter to reference the setup. I actually referenced them out at about 85db which is a little louder then most of my friends like, which might be why I always get so blown away by the action when it starts but you cant really feel like you are there unless you can feel it right :0)
I think it just might be time for myself to focus on getting an amp for the CSi5, I know it needs it and it just might help more then I thought.
