pre/pro question
beardog03
beardog03 Posts: 5,550
edited September 2005 in Electronics
If you are using seperate amps, and your AVR is just being used as a pre/pro...
does it matter which one you use ie;yammie,dennon etc. ?
it`s the amps that make the difference right..
I won`t hear/notice much difference betwen the yammie and the dennon...right ?
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool:
Post edited by beardog03 on
  • gregure
    gregure Posts: 871
    edited August 2005
    Actually, while a better amp will give you smoother sound, more details, and better bass, this is due to giving the speaker more juice. An amp is just power. It is the preamp that has the most effect on the character of the sound, so the difference between Denon, Yahama and Pioneer Elite is still very noticeable even when a separate amp is thrown into the mix.
    For example, it has often been stated that Krell gear tends to be on the bright side for music, although for movies it is probably some of the best gear available. However, a Krell monoblock amp is simply sheer power, which could realistically be used with any preamp/speaker system without causing brightness. It is the preamp that processes the sound and may tend toward brightness, although this can be tamed or minimized if using analog connectors for music playback.
    Current System:
    CSi5-Center (for sale**)
    FXi3-surrounds (for sale**)
    Martin Logan Depth-Sub
    B&K AVR 507
    Pimare CD21-CD Player
    Denon 1815-DVD Player
    Panamax M5500-EX-Line Conditioner
  • madmax
    madmax Posts: 12,434
    Put another way, all the small crappy sounds you currently don't notice become louder and much more annoying. An excellent pre-pro is necessary to get beyond a particular level. Of the two you mention one may sound better than the other but it's a crapshoot.
    madmax
    Vinyl, the final frontier...
