making door speakers sound better?
fgreco
fgreco Posts: 6
edited September 2005 in Speakers
I have polk speakers 5x7 inch in my 97' mercury mystique. I have them in the doors so I put them on and they, make the doors shake causing a distortion noise. I ve see padding you can put behide the speaker will it help or what will help. Thanks to everyone in advace who replys to this thread.
Post edited by fgreco on
  • screxer
    screxer Posts: 29
    edited August 2005
    Try posting in the car audio forum....You should find some help there pretty quick.
    Haman/Kardon AVR635
    Polk Audio Monitor 70x2
    Polk Audio RTi38x2
    Polk Audio RTi28x2
    Polk Audio CSi30
    Velodyne DPS-10
  • MacLeod
    MacLeod Posts: 14,358
    edited August 2005
    You should check out the Car Audio section of this forum for help as this is for home audio but Ill go ahead and give ya some tips.
    1st take some 1/2" plywood and cut out a baffle to mount the speaker on. This will be a much sturdier mounting surface than the thin metal door panels.
    The stuff youre talking about is made by a bunch of different manufacturers but the most popular is Dynamat. Here. Coat the door panel as good as you can and even inside the door. This will make the door panel much more solid and virtually eliminate vibrations. It also wouldnt be a bad idea to cover your baffles with Dynamat. Here is a thread I made when I installed a set of speakers in my truck last year. Youll see what I mean by baffles and damping them.
  • fgreco
    fgreco Posts: 6
    Thanks, I really appreciate it.
    I have polk db570 or dbs70 I can not read the box to well. They were buy one get the next half price and they sounded the best.
