How to connect a 4 ohm sub
propman07
Hello-
I am sure that this has been asked before, but I couldn't find anything with the search button.
I have an order of Polk speakers on the way from crutchfield.com. I ordered the following:
2 RTi10 Floor Standing Speakers
1 CSi5 Center Channel Speaker
2 FXi3 Surround Speakers
On the advice from other forum members, I ordered my subwoofer from SV Subwoofers. Here's what I got.
1 SVS PB12-ISD Subwoofer
All of the Polk speakers are listed at 8 ohms. The subwoofer is rated 320 W at 4 ohms. I have a Yamaha RX-V2500 receiver, which can switch the speaker output between 8 ohms and 4 ohms (if I remember correctly).
Am I going to have a problem connecting the sub to the receiver?
Thanks in advance.
Thanks in advance.
David
HT Setup
Display: Sony KDF-60XS955
Receiver: Sony STR-DA5000ES
Front Main: Polk RTi10
Center: Polk CSi5
Surround: Polk FXi3
Subwoofer: SVS-PB12-ISD
HT Setup
Center: Polk CSi5
Surround: Polk FXi3
Post edited by propman07 on
The sub has it's own amp and does not require power from the receiver's amp. Just hook it up to the sub-out rca on the receiver and you'll be fine.
One another thing: Don't forget to calibrate. Page 6 on your manual has a nice guide on how to calibrate.Receiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
Rear Surrounds: polk R20
Subwoofer: polk PSW404
DVD: Panasonic DVD-S29 -
Agree with Mike.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Mike682 wrote:The sub has it's own amp and does not require power from the receiver's amp. Just hook it up to the sub-out rca on the receiver and you'll be fine.
Mike682-
Thanks for the reply. Damn it, I KNEW that one, but I wanted to make sure.
I'll be sure to check out Page 6 on the manual.
Thanks again.David
HT Setup
Center: Polk CSi5
Surround: Polk FXi3
Subwoofer: SVS-PB12-ISD -
disneyjoe7 wrote:Agree with Mike.
Thanks, disneyjoe7David
HT Setup
Center: Polk CSi5
Surround: Polk FXi3
