top 10 things not to do to your car/truck...
PoweredByDodge
PoweredByDodge Posts: 4,185
edited September 2005 in Car Audio & Electronics
a little compilation of things i've run into in the last year. some are funny, some are not. but by all means, things to avoid.
10- running all your positive power lines, 4, 8, whatever gauge, for everything from wipers and the heater to your system and other stuff, and then realizing that after you put all the shiny gold ends on,that they aren't the right length, and they don't all reach the (+) battery terminal.
9- using a cheap oil filter wrench to remove / put on an oil filter. you will inevitably end up slipping the wrench around the little knurly grippy things and smash the buggers... resulting in a filter that's either going to leak immediately or burst soon.
8- removing an oil filter that you put on way too tight by stabbing a screw driver through it and then trying to "wrech" it off like that. won't work. just won't, but it will get you extremely angry, covered in used oil, and cut up by the metal casing of the filter. gigantic c-channel pliars, however, do work. ... remember, hand tight, then 3/4 of a turn.
7- overtightening bolts. i have spent probably as much time removing broken bolts as i have building this damn truck. i finally invested in a torque wrench. the best 70 bucks i ever spent at home depot. (just got one out of hte oil pan, who'd have thought 40 ft pounds was too much for an oil pan screw! - apparently spec is "9").
6- the cart before the horse. don't put the transmission mount in before you've actually bolted it to the transmission. likewise, don't run new stainless fuel and brake lines before you're done welding and cutting certain portions of the frame.
5- don't get an intake manifold with a 2 inch rise, a carburetor adaptor with a 1 inch rise, an egr spacer with a 1 inch rise, and an air cleaner spacer with a 1 inch rise and expect your actual air cleaner to friggin fit under the goddamn hood. stupid egr.
4- 9 o'clock at night is not a good time to start a project.
3- laying in a pool of used motor oil, power steering fluid, antifreeze, and the kitty litter you were trying to clean it up with will most certainly give you a chemical burn when not wearing a shirt. it will also not get you ladies if you're a portly gentleman like myself.
2- uncle jack can't fix it if you break it even more before he gets there.
1- while a girl may have "relations" with you when you're covered in that spray on 3M rustproofing stuff, she's not somebody you want to bring home to mom. but you may want her at your stag party.
and now - the bonus !
0- while it may seem cool to DJ your block party, hours of repairs and blown audio components are not something you want to deal with.
The Artist formerly known as PoweredByDodge
Post edited by PoweredByDodge on
  • Toxis
    Toxis Posts: 5,116
    edited August 2005
    Hmmm... shouldn't this thread be called "Not-so-common sense" ? ? ? :p;):D
  • michael_w
    michael_w Posts: 2,813
    edited August 2005
    That was funny... I especially liked #5. The more mistakes you make the more you learn. On the other hand, thanks for letting us know what not to do ;)
  • hellohello
    hellohello Posts: 428
    edited August 2005
    Sounds like mp3s are the devil, like the RIAA suggests :eek:
    Picking ones nose signifies a strong sense of self discovery :)
    System in the works: ;)
    PP 6V6 with 12ax7 pre ~ 20 watts
    15" Jensen MOD 8ohm ~ 97db SPL
    DiMarzio HS3 and/or Tone Zone S
  • Jstas
    Jstas Posts: 14,842
    edited August 2005
    Dude, duh! I thought I learned you better than that! :p
    Expert Moron Extraordinaire
  • PoweredByDodge
    edited August 2005
    i dun need ta git learned gooder next time, i thinks.
  • PoweredByDodge
    edited August 2005
    My buddy and I have t-shirt that explicitly state "F the RIAA"
    www.unitethecows.com
    www.zeropaid.com
  • PoweredByDodge
    edited August 2005
    I will die due to lack of warmth.
    How Will You Die?
  • hellohello
    edited August 2005
    Is it just me, or does boredom run rampant?
  • Jstas
    Jstas Posts: 14,842
    edited August 2005
    Imma gonna die in a terrorist attack!
  • neomagus00
    neomagus00 Posts: 3,899
    edited August 2005
    Apparently I'll die alone :(
  • CrBoy
    CrBoy Posts: 580
    edited August 2005
    the same here... :(
  • PoweredByDodge
    edited August 2005
    for anyone who didn't "get it" - it's this weird link i found - there's this thing that you put in some information about you and it'll "tell you how you will die" - go figure... it amuses me.
  • george daniel
    george daniel Posts: 12,096
    edited August 2005
    I will die in a terrorist attack
  • MacLeod
    MacLeod Posts: 14,358
    edited August 2005
    Ill fall off a cliff.
    Thats fuggin' hilarious Vin.
    #4 I know all too well. I cannot count the hours Ive spent under the lightpost in Kmart parking lot at 11 at night because a new way to mount my amps suddenly dawned on me!
    #2 is also familiar. After I break something and sit in the house cooling off for a while, for some reason I figure that if I go back and try it again I wont break it anymore!
  • spwuinmk67
    spwuinmk67 Posts: 797
    edited August 2005
    I'll die when the sun explodes. Oh joy....
    1993 Ford Ranger super cab:
    Pioneer Premier DEH-P880PRS
    MB Quart QSD216
    in need of amps and subs
    Home:
    52" Sharp Aquos
    PolkAudio Monitor 10's
    Harmon Kardon HK3375
    Xbox 360
    PolkAudio XM tuner
    Owner and co-designer of www.basicholdem.com
  • hellohello
    edited August 2005
    I will die in the gas chamber. YAY! :D
  • hellohello
    edited August 2005
    ebonics translator:
    i will die in the gas chamber.
    translates to
    meh will die in da gas chamber.
  • PoweredByDodge
    edited August 2005
    hellohello wrote:
    ebonics translator:
    translates to
    italian translation...
    " i will die when cousin louie finds out about the 200 bucks i stole from his safe after i slept with his wife... then he'll throw me in the garage with the car runnin and shut the door - if i try to get out, he'll shoot me. "
  • MacLeod
    edited August 2005
    What the hell are you two talking about???
  • neomagus00
    edited August 2005
    absolutely nothing at all, i'd have to assume... but i find it quite impressive that you can spend several hours at 11 at night in a parking lot... does time flow differently at kmart? :D
  • MacLeod
    It does if youre there more than one day.
    I used to work at a restaurant when I was 18-20 that was in the shopping complex along with a Kmart. I would think of some knew thing to do to my system (88 Olds Cutlas Calais) and after work Id park under one of the lights and re-work it. Also did this if something quit working while I was out running around at night. Find a parking lot at and light post and go to work.
  • swerve
    swerve Posts: 1,862
    www.zeropaid.com
    "Sharing is Caring... **** the RIAA!"
    I wanted a shirt that said that so bad but i never ordered one...
    cats.vans.bag...
  • AustinKP
    AustinKP Posts: 861
    I will die when the tree falls on my head...
    crap
    http://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
    Alpine 9815
    Ascendant Audio Atlas 12
    2 Gallons SecondSkin Spectrum V.2
  • beardog03
    beardog03 Posts: 5,550
    It say`s I will die in a plane crash...
    is that going to be going to the Polkfest , or on the way back..?
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • ND13
    ND13 Posts: 7,601
    I will die in a terrorist attack ,also. Oh ****, not at Polkfest, I hope!!!!! :eek: :D
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • W WALDECKER
    W WALDECKER Posts: 900
    i will die in the zoo. does that mean in a future incarnation ?
    Rogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
    .Audience AU24SE speaker and ic cables- Chord Qutest DAC - Black Cat Silverstar II 75ohm digital cable-Tyler Acoustics Linbrook Signature system with large bass cabinets to accommodate 10" Seas magnesium woofers.2xhmpsuownoj.jpg
  • MacLeod
    Im sure its talking about your dog!
    Those Jack Russel Terrorists can be quite mean when they want to! ;)
  • ND13
    ND13 Posts: 7,601
    She knows who saved her **** from the kennel :p . It drive's my wife nuts that I have such a calming effect on her, cause she's a freakin tornado when I'm not in the room.
  • audiobliss
    audiobliss Posts: 12,518
    Man. I'll die in a plane crash, too. I knew I should have said I was wearing shoes, lol.
    That's a hilarious list, PBD!!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • audiobliss
    Ah-ha. If I change it to 'I'm wearing shoes', I die while I'm being mugged. (That's a legit change, 'cause I never go around barefoot; just happen to be right now.) That prediction makes more sense, too. 'Cause I would not give up something to a stupid mugger. I'd fight 'em 'till one of us was down. And considering a mugger would probably be Mac's size - and I'm not, I'd probably be the one to be down.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
