RPTV Problems Sony 57" HDTV
HBombToo
Over the past month I noticed that curved thin red lines will appear in an arc across my screan. The spacing between the red lines are dependent on a standard frame, 480P, 720P or 1080i.
Could this be indicative of balbs going bad or is there sme sort of scan issue with the TV? Its a good TV overall but I'm unsure what would be required to fix the issue.
HBomb
HBomb
***WAREMTAE***
Post edited by HBombToo on
you need to converge the guns. It's manual via your menu. Go to the advanced screen (if it's optional) so you have a huge grid across the entire tv. Now go step by step starting in the top left corner and going in a clockwise circle until you hit every adjustable area. Once you're done... do it again. Once you finish the second go-round... enjoy your beautiful image once again.Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
Well there is nothing in the menu for an advance set up but there is an auto convergence button that I used with no help.
Looks like I have a serious problem somewhere....
h***WAREMTAE***
