What receiver and/or amp should I buy?
dwc56
First, thanks in advance for any help you may give me. I am new at this and am upgrading my stereo for the 1st time in 10 years.
I think I have settled on buying the following speakers:
Front Lsi9
Surround Lsi7
Center LsiC
1) Any advice on a receiver and/or amp that would go well with these speakers? (I'd like the total cost for the receiver and/or amp to be in the $1000 - $1500 range, but would be willing to pay a little more).
2) If you do recommend amps, do I need them for the front, center and surrounds? Or just for the front speakers?
3) Any recommendation for a sub in the $700 - $900 range?
Again, thanks in advance.
- Dave
Front Lsi9
Surround Lsi7
Center LsiC
- Dave
Post edited by dwc56 on
Nice choice of speakers. I would put amps on all 5 channels. Maybe an Outlaw 750 "used" if you can find one. Marantz 9000 also comes to mind, as a nice 5 channel amp that could drive those nicely. Just don't starve them with a receiver to get alot of bells and whistles without guts. Any receiver that has preamp outputs will do nicely.
Oh, and Welcome to CP!!!HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Welcome to the forums!
1. Kenwood.
j/k. 2. What Dennis said. Start with Outlaw, Rotel, B&K's receivers, Adcom- Ebay and Audiogon are nice resources you can use- I recommend all channels on amps.
3. for $900- you can buy a real mean SVS. -
I think B&K would be an excellent choice for an all-in-one receiver, although it overshoots your budget at $3200. Rotel would be an excellent choice in the lower price bracket. If going with amps, many here like Outlaw, I've no personal experience with it, but they've always gotten good reviews. I think Rotel is probably the best receiver in that price range, maybe the $1500 Marantz piece. Adcom has some pretty decent stuff for lower pricing, although a good separates system will still cost $3000-5000.
For subs, look into SVS, however another sub I can't say enough about is the Grotto from Martin Logan. Small, attractive, 10" aluminum woofer with tight, articulate bass, +/- 3db to 22Hz. Fills up a room nicely and is excellent for music. It has a triangular shape which makes it perfect for a corner. Runs $1000. SVS would probably out perform it in extension by a few Hz, but would be twice as big. Depends on your aesthetic requirements.
Take a look:
Grotto
SVS PB12-PlusCurrent System:
CSi5-Center (for sale**)
FXi3-surrounds (for sale**)
Martin Logan Depth-Sub
B&K AVR 507
Pimare CD21-CD Player
Denon 1815-DVD Player
Panamax M5500-EX-Line Conditioner
