QUestion abt instalation...
SamSagaZ
SamSagaZ Posts: 321
edited August 2005 in Car Audio & Electronics
the weekend i was inserting the wires for the speakers and subs in my car
i put some wires of the speakers in the panel of the car, will this put some noise to the signal?
ill show it in an picture take a look
sorry for my english hope u understand
Post edited by SamSagaZ on
  • audiobliss
    audiobliss Posts: 12,518
    edited August 2005
    Man; that's a lot of wires. Hope you get your problem/s resolved!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • SamSagaZ
    SamSagaZ Posts: 321
    edited August 2005
    no, not tuu much, i just want to know if the blue/platinium wire (are the wires that i put for the speakers) will have some kind of NOISE in the place where i put it.
    its under the "balance wheel" dont know if its right spelled :)
  • exalted512
    exalted512 Posts: 10,735
    edited August 2005
    you should be fine, if you start it up and get noise then move them
    -Cody
  • MacLeod
    MacLeod Posts: 14,358
    edited August 2005
    I think youll be fine as well. Speaker wire doesnt pick up noise that easy. Theyre not nearly as susceptible as RCA's.
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    edited August 2005
    first - that's not a lot of wires. the door panel is off, and those are the panel controls. also those are the wires (stock from car) behind the dash... he's only got the two blue/silver wires that are "new".
    second - i agree with macleod, speaker wires should not pick up interference the way RCA's do. with about 15 - 20 volts going through those speaker wires, you won't have a problem with any interference. it's the 2 volt RCA lines that you have to worry about keeping away from other power sources.
    The Artist formerly known as PoweredByDodge
  • SamSagaZ
    SamSagaZ Posts: 321
    edited August 2005
