problems with setting up a remote desktop connection / terminal services client
michael_w
michael_w Posts: 2,813
edited January 2013 in The Clubhouse
Well today I tried setting up a remote desktop connection (formerly called a terminal services client) and havn't had much luck in getting it working. I followed a tutorial online (linked here) and managed to get to the point where I can get to the remote desktop web connection site. When I click connect I get this message:
"The client could not connect to the remote computer. Remote connections might not be enabled or the computer might be too busy to accept new connections. It is also possible that network problems are preventing your connection. Please try connecting again later. If the problem continues to occur, contact your administrator."
I'm not quite sure where to go from here to get this working other than to go over it again and make absolutly sure I did everything correctly.
Any input would be great as I'm a little lost and would really like to get this up and running.
Thanks,
Michael
Post edited by michael_w on
  • michael_w
    edited August 2005
    OK I figured it out and I can say that even though it was a pain in the **** to set up it is FREAKIN SWEET!! Now I can control my computer in my room through my pocket pc from any hotspot or from any computer that has internet access.
    The only thing I overlooked when trying to set it up this time was that I forgot to open one port on my router. Since I have a few firewalls I lost track and missed one but it's working just dandy now.
  • rickyaliasgar
    rickyaliasgar Posts: 1
    edited January 2013
    Try establishing remote desktop connection using various remote support tools such as logmeinrescue, gosupportnow, GoToMyPC etc. and check whether it works or no.
  • rtart
    rtart Posts: 833
    edited January 2013
    It is a great (and IMO underused) feature of Windows. I have a PC running Win Media Player dedicated to one source of my Russound whole house audio system. I do have a Streamzap remote attached, and the Russound system will do IR remote command mimicing from each zone's keypad. However, the commands are limited to play, pause, skip, etc. and RDC gives me the ability to access the PC from any other PC on my network, including a netbook that I use wirelessly. Just have to rememebr to enable audio from controlled PC or the music plays on the netbook, not the music PC. Works great!
    I'm investigating an Android app that will give me similar control - just haven't found it yet.
    My 7.4.4 DIY 4k Home Theater:
    Polk LSiM 707 L-C-R, LSiM702 side surrounds, LSiM 705 rears
    Polk LSiM 702s x 4 on the Ceiling Atmos speakers
    2 x SVS PB12/Plus 2's
    Denon X3700H
    Emotiva XPA11 Gen 3
    XBox One X 4k & BD and streaming
    Panasonic UB-420 4k player
    HD-A35 HD DVD
    Oppo BD-103D for hirez audio
    Technics SL-D2 TT, Grado Gold Cartridge
    JVC DLA-RS2000/NX7 projector
    Silver Ticket 120" acoustically transparent screen
    Berkline 090 electric recliners with Aura Bass Shakers
  • goofyGAguy
    goofyGAguy Posts: 545
    edited January 2013
    Did you happen to notice the date on the OP? :wink:
    My humble setup...
    ...is no more. :cry:
