Chemistry/math problem quick help :D
audiobliss
audiobliss Posts: 12,518
edited April 2024 in Clubhouse Archives
Ok, I'm trying to figure out a problem for a friend here. This is the problem:
A copper refiner produces a copper ingot weighing 2.39 kg. If the copper is drawn out into a wire of diameter 1.400 mm, how many feet of copper wire can be obtained from the ingot? (The density of copper is 8.94 g/cm3, Volwire = pr2l.)
I personally haven't ever done a problem like this, but it seems pretty straight-forward. This is how I'm inclined to do it: (I don't feel like typing all this again, so I've pasted in how I tried to explain earlier how I *think* you can do it:
Ok, well. The only thing we know about this wire that we want to make is that its diameter is 1.400mm. So, we're going to have to use volumes to figure this out (as far as I can tell). We can convert 2.39kg into grams and use 8.94g/cm^3 to figure out the volume of copper that we have in cm^3. Then we can convert that to mm^3 to work with the cylinder. Once we have that, we can use the formula for the volume of a cylinder (the wire) to find out how long it is. How? Because we know two of the variables: volume (the answer), and the diammeter. We can plug those two values into the formula for the volume of a cylinder, and find out the height, or the length of the wire.
Doing it like this we have: 2.39kg x 100 = 2390g. 2390g (divided by) 8.94g = 267.3378076cm^3 of copper. Now we convert to mm^3: 267.3378076 x 1000 = 267337.8076mm^3. We can now plug this into the formula for the are of a cylinder to find the height of the cylinder and thus the length of the wire. V = base x height. Base: A = pi(r)^2. A = pi(.7)^2 = 1.5393804. So, now we have 267337.8076 = 1.5393804 x h. We divide by 1.5393804 and get h = 173665.8512mm.
So, our wire should be 173665.8512mm long. Since we're asked for feet (thanks bobman1235!!), divide this by 10 to get cm, then divide by 2.54 to get inches, then divide by 12 to get feet. I'm sure there's a more direct way to do that, but I don't know it. This gives us 569.769853 feet.
Now, I don't know if I did that right. I have no idea what the 'Volwire = pr2l' means, so I'm suspecting I did something wrong. If you can help me out with this, I'd really appreciate it!
Thanks!
Jstas wrote: »
In Use
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
  • MacLeod
    MacLeod Posts: 14,358
    edited August 2005
    Show off.
  • audiobliss
    edited August 2005
    MacLeod wrote:
    Show off.
    :p
    Since I'm asking for help...I don't really feel like a show off....but hey, if I am.....cool!! :D
    Oh, and thanks for the help! :D
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • MacLeod
    edited August 2005
    Glad to be of service! :D
    The fact that you actually know what all that means shows youre a lot smarter than me! I guess Im just jealous! :p
  • audiobliss
    edited August 2005
    I said I don't know what the 'pr2l' means....lol
    Has nothing to do with smarts. Just means I've learned about it.
    However, trying to build a 'box' with 4 sides does have do to with smarts! :D:D:D
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • bobman1235
    bobman1235 Posts: 10,822
    edited August 2005
    pr2l is supposed to be (pi)r(squared) times length... which si what you correctly assumed.
    They kinda trick you in the question by asking how many FEET you get, so convert your mm to feet (just type it into google...).
    Pretty close though :)
    (edit : just realized i corrected something you didn't even do wrong... i'm an ****)
  • MacLeod
    edited August 2005
    You better believe it! Not just anybody could pull that off! ;)
  • audiobliss
    edited August 2005
    Thanks bobman1235. Yeah, another friend pointed out my problem with the mm^3 (and told me what the 'pr2l' was supposed to be). I hate it when they give you those formulas when you should be more than able to figure it out yourself. I mean, I've never done a problem like that, and I figured it out.
    I fixed the mm^3 in the quote above. Hmm. I hadn't seen the feet at all, lol! I'll see if I can't convert it.
    Thanks!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • audiobliss
    edited August 2005
    bobman1235 - ROFL Yeah, I did have it wrong, but I corrected it for reference.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Shizelbs
    Shizelbs Posts: 7,433
    edited August 2005
    Sorry if I wrong, or if it was just a typo, but the factor for converting inches to centimeters is 2.54, not 2.94.
  • audiobliss
    edited August 2005
    Thanks, shizelbs! That's where I'm wrong! My answer wasn't quite adding up! I bet that's it! Man, it's been a long time since I've worked with these conversions!
    Thanks!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited August 2005
    1.0" = 1.0 / .03937 =25.4000508 mm / 10 = 2.54000508 cm
    1.0' = 1.0 x 12 = 12 / .03937 = 304.8006096 mm
  • audiobliss
    edited August 2005
    Where are you getting the '.03937' from?
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • petrym
    petrym Posts: 1,912
    edited August 2005
    I got 64.004764258729 meters, which converts to 209.989390771 feet. Round it up to 210 feet and call it good!
    All unit conversions handled internally by TI-89 calculator.
    My calcs: 1st get the volume of the sphere (2.39 kg) / ((8.49 gm/cm^3)) = .000282507656m^3
    solve for the radius of the sphere: v=pi r^2 l = .040656863076m
    solve for the length of cylinder by pi ^2 h(height or length in this case) since the volume remains the same = l = Vol/(pi r^2) = 64.004764258729 meters
  • beardog03
    beardog03 Posts: 5,550
    edited August 2005
    my brain hurts...!!
    hey,whats that liquid stuff running out of my ears..?!!
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • cfrizz
    cfrizz Posts: 13,415
    edited August 2005
    beardog03 wrote:
    my brain hurts...!!
    AMEN!!
    2 mind numbing threads so far!!!! What is there a full moon out tonight or what? :eek:
  • Ron-P
    Ron-P Posts: 8,520
    edited August 2005
    Hey, don't forget the +1
    If...
    Ron loves a film = don't even rent.
  • Mike682
    Mike682 Posts: 2,074
    edited August 2005
    That's why I love stats.....most gets calculated on the computer..I couldn't imagine inverting a matrix by hand...
    Receiver: harmankardon AVR235
    Mains: polk R30
    Center: polk CSi3
    Rear Surrounds: polk R20
    Subwoofer: polk PSW404
    DVD: Panasonic DVD-S29
  • CrBoy
    CrBoy Posts: 580
    edited August 2005
    I used know all this Chemistry stuff but I forgot pretty much everything I knew on this subject... I feel stupid now...
    billbillw Posts: 8,350
    edited August 2005
    There is really no chemistry involved in this problem.
    It is purely geometry calculations, a little physical science (density), and basic unit conversion.
  • CrBoy
    CrBoy Posts: 580
    edited August 2005
    sure... I based my comment only in the thread name... not in the actual content of the posts
  • Polkersince85
    edited August 2005
    A meter is 39.37 inches. a mm is 1/1000th of a meter.
    Divide inches by .03937 to get mm.
    Multiply mm by .03937 to get inches
    Just an accurate conversion factor to remember IMO :confused:
  • aaharvel
    aaharvel Posts: 4,489
    edited August 2005
    math is almost as bad as learning a foreign language. I feel your pain.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • petrym
    petrym Posts: 1,912
    edited August 2005
    I made an oops in my original equations of making the radius of the wire as 1.4mm versus the actual value of 1/2 diameter of .7
    That makes the revised length as 128.009528517 meters = 419.978781541 feet or about 420 feet.
    audiobliss, did you ever get the proper answer from your friends work?
  • audiobliss
    edited August 2005
    No, I didn't. I should ask her to see who's right; we have three answers now, I believe! lol
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
