CSi5
huy30
I need some help about CSi5 center speaker. This is my first set of surround speakers. I see that this speaker has 4 connectors on the back (2 positive and 2 negative). I looked at the manual and saw that you can have different setup. I just want to use this as center speaker, so I just use any set of 1-red and 1-black connector? Thanks.
Post edited by huy30 on
Yes, as long as the brass plates connecting the two reds and two blacks are in place.Main System:
PreAmp: Rotel 1098 with MF X-10v3
Amp: Rotel 1090, 1075, 1070
Source: Pro-Ject RM9 with Blackbird Cart., Denon 2900 with MF X-DACv3
Speakers: Gallo Ref 3s (LR), Gallo Due (C, SR, SL), Gallo Micro (RR, RL)
Second System:
Receiver: H/K AVR 630
Source: Pioneer 563
Speakers: Polk RTi10s (LR), CSi5 (C), RTR 200 (SR, SL) -
the 2 terminals are for bi-wiring. whether u use both sets(make sure you remove the jumpers if you do) or just the one it will still only play the center channel sounds. what the 2 two terminals does is take the high freq's and low freq's and split them up. some say it sounds better, others dont notice a difference. the choice is up to your ears!
