Cable TV from wall to receiver?
Schris22
Basically live in a dorm room, there is no box....soooo how do I hook the cable from the wall to the receiver? Do I need some kind of adapter?
or just live with cable through TV stero speakers...haha...which is no biggy just got everything running through the receiver so might as well have TV on one input as well..
K
Thanks,
Chris
K
Thanks,
Chris
Receiver: Onkyo TX-SR502-S
DVD Player: Pioneer DV-578A-S
Left and Right: R50
Center: CS1
Rear Center: R15
Surrounds: R30
Subwoofer: 10'' Dayton 100 Watt
Left and Right: R50
Center: CS1
Rear Center: R15
Surrounds: R30
Post edited by Schris22 on
You would want to make sure it is a hi-fi(stereo) vcr if you plan on watching things in Pro Logic or even stereo. The vcr will have a left and right audio output that will feed directly into a receiver.
ZachTschüss
Zach -
sounds good I'll look into the VCR....b/c the tv only has audio INputs...
Thanks,
ChrisReceiver: Onkyo TX-SR502-S
Left and Right: R50
Center: CS1
Rear Center: R15
Surrounds: R30
