Need advice on color scheme for HT room
landry_p2000
landry_p2000 Posts: 1,313
edited April 2024 in Clubhouse Archives
Hello good people.
I am in the process of painting the rooms in my house, and I am open to suggestions for a color for the HT room. I know that the room should be a dark color, I just dont want to go wrong in my color selection. The old lady doesn't give a rats a$$ about what color I use, but I don't want to choose an ugly color. I was looking at a dark maroon or dark grey color. Help! :confused:
Landry
Main Set-up: 55" 120 hz Samsung LN55B650, Onkyo TX-SR806, Emotiva XPA-5, Emotiva XPA-2, PS3 Slim, Sony BDP-S560, Apple TV (160g), Panamax M5300-PM, Polk Audio CSi5, RTi10's, FXi3's, RTi4's, and SVS PB12 Plus
Bedroom: Panasonic 50" S2 Plasma and Panasonic BD65 blu-ray player, Onkyo TX-SR707, Emotiva XPA-3, Emotiva UPA-2, KEF IQ7's, IQc, IQ8Ds, and SVS PB10-ISD
  • Mike682
    Mike682 Posts: 2,074
    edited August 2005
    Dark maroon would be nice. But you might have more options. I thought that a dark room is very important with a projector setup and not so much with a TV due to brightness differences...
    Either way, maroon would be nice
    Receiver: harmankardon AVR235
    Mains: polk R30
    Center: polk CSi3
    Rear Surrounds: polk R20
    Subwoofer: polk PSW404
    DVD: Panasonic DVD-S29
  • ND13
    ND13 Posts: 7,601
    edited August 2005
    I was thinking maroon myself, before I even got to the end of your post. So it looks like maroon.
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • landry_p2000
    edited August 2005
    Thanks for the input guys. I think maroon will be a good color. Pam didn't cringe when I mentioned that color to her, so that will probably do it. :)
  • landry_p2000
    edited August 2005
    The dark walls would still make the TV picture more pronounced than an eggshell wall, wouldn't it Mike?
  • Mike682
    edited August 2005
    Sure..I was just saying that you weren't limited to very,very dark colors (like black) etc with a TV and that maroon was a good choice
    Mains: polk R30
    Center: polk CSi3
  • landry_p2000
    edited August 2005
    Oh, okay. Thanks for the quick reply. I guess I will do a little work now. :D
    Maroon, it is!
  • Mike682
    edited August 2005
    Get painting!! :D If you can, post some pics
    Mains: polk R30
    Center: polk CSi3
  • landry_p2000
    edited August 2005
    Will do. I have to paint her living room first. :rolleyes:
  • ND13
    ND13 Posts: 7,601
    edited August 2005
    Landry,
    Make sure you DON'T use a "shiny" finish like gloss or semi-gloss. You don't want any light refecting off the walls. Use satin or flat.
  • landry_p2000
    edited August 2005
    ND13 wrote:
    Landry,
    You read my mind. I plan on using flat. I never liked "shiny" walls anyway. How would you describe a "satin" finish paint? :confused:
  • ND13
    ND13 Posts: 7,601
    edited August 2005
    A satin finish is in between flat and semi-gloss and is alot easier to clean than flat. I myself would use a satin finish.
  • landry_p2000
    edited August 2005
    Okay. Thanks for the info. This is my 1st home, and I hate the white or eggshell walls that everyone uses in houses. :rolleyes:
  • ninerbj
    ninerbj Posts: 870
    edited August 2005
    Is anyone going to ask the question that matters most in selecting HT paint colors???
    F*#K IT!! I will....
    Are there any windows in this room that may reflect the outside light?
    "she had the body of Venus, with arms."
  • Shizelbs
    Shizelbs Posts: 7,433
    edited August 2005
    If and when I do it, I've wanted to do maroon as well. WSU colors. I think it goes nice with many carpet colors as well as any wood work that also may be in the room.
  • Ron-P
    Ron-P Posts: 8,520
    edited August 2005
    Black, no other color will do. I tried several colors, dark colors, even gray and nothing came close to black. It may "look" like a cave but when the lights go out the image on the screen with shine and THAT is what you want.
    Me too. We do not have a single white wall in the house, nada one. Every wall is painted with color.
    If...
    Ron loves a film = don't even rent.
  • Frank Z
    Frank Z Posts: 5,860
    edited August 2005
    Linky below.
  • Frank Z
    edited August 2005
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited August 2005
    Maroon I have 2 walls painted in that color, it's Home Depot's Currant Jam ICC-83 in Eggshell Enamel. It's striking but a major pain too paint that color, it was 5 coats before I liked it. Ok 4 on one wall but I used a primer first, so I counting that as 5.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • landry_p2000
    edited August 2005
    Yep. There are black curtains up to the windows. No light can get by. :)
  • landry_p2000
    edited August 2005
    Yeah Ron. I wanted black at first, but this room is opened with no door. I plan on adding one in the future, but it is visible from the kitchen.
  • Ron-P
    Ron-P Posts: 8,520
    edited August 2005
    I understand. The main reason most do not go with black is because the room is usually used for other purposes or visible from other rooms in the house. But, if you can pull it off you will not regret it. Add the door first then paint it black. After all, you don't want all the sound blasting into other parts of the house, do you? :)
    If...
    SCompRacer Posts: 9,406
    edited August 2005
    ND13 wrote:
    Landry,
    Semi and gloss paint will also make any defects in the wall stand out too.
  • Ron-P
    Ron-P Posts: 8,520
    edited August 2005
    Avoid satin as well, only use flat.
    If...
  • landry_p2000
    edited August 2005
    Okay. I am going with a flat maroon color. This room also has chair rails all the way around, and I may leave them white.
    Ron, the black was my first choice mainly because I am a Raiders fan. :D
  • jdhdiggs
    jdhdiggs Posts: 4,305
    edited August 2005
    Dark Blue's would seem to reflect less obvious light, or at least in my mind. :confused:
    Another thought on the finish would be to go check out some of the "textured" finishes. Some are quite rough, almost like sand paper. This would, in my mind at least, diffuse both sound and light bouncing around the room.
    That said, i'm just throwing darts in the dark here and don't know squat on this topic.
    There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
  • landry_p2000
    edited August 2005
    Don't feel like the Lone Ranger. I don't know about this myself. :confused:
    That's why I asked the "Big Dogs" for input. ;)
    Thanks for the input anyway JD. Dark Blue would also be a cool color to use, but I am probably sticking with the maroon color scheme.
  • landry_p2000
    edited August 2005
    Frank Z wrote:
    Nice room Frank! I like the color in your room also. I want to go a little darker shade of red, burgundy, or maroon. Your room doesn't appear to have any windows which is pretty cool for a home theater room. Nice set-up as well.
    By the way, my room is about 23'x14', and I was wondering about how many gallons would I need to do about two coats?
  • Ron-P
    Ron-P Posts: 8,520
    edited August 2005
    Standard 8' high ceilings? If so, your looking at 592sf of wall to cover. The average gallon will cover 350sf. I'd say you'll be safe with 3 gallons. You need to deduct square footage for doors, windows and such.
    Be sure to mix all 3 gallons together before you paint.
    If...
  • landry_p2000
    edited August 2005
    Thanks Ron. Will the paint show up a different shade if I don't mix them up? :confused:
    VR3 Posts: 29,759
    edited August 2005
    A good way to mix paint (large amounts) is to get an attachment for a drill that is like a big mixer... very fast, very effective and you wont be able to mix it any better for a constant color.
    Semi Gloss/Shiney finishes are not that bad and arnt that shiney in actuality, they just require so much prep work that will make your head absolutely spin. They show almost every kind of blemish on your wall, and I mean any and everything. I should know, I just painted some crappy walls with semi gloss paint. Not to mention semi-gloss is really thin paint and takes a few coats.
    PAINT YOUR CEILING FIRST!!!!!!!!!!!!!!!! This is an absolute MUST...
    1) It seals your ceiling
    2) It looks alot better
    3) It makes sense
    4) It looks alot better
    5) It looks alot better
    USE ALOT OF CAULK, put it around the door ways, the moulding - this is DEFINITE improvements if it hasnt already been done.
    I used a color called Meteorite Gray... has a shade of blue to it... (Interprise (Lowes) - Meteorite Gray)
