Phoenix Gold Amps for MMC6500/MMC650 Speakers
rbarbera75
I am finally done with installing my speakers. I have the following installed in my RSX:
Polk MOMO MMC6500 (Front)
Polk MOMO MMC650 (Rear)
So we all know the MMC6500 are rated at 125W RMS and the MMC650 are rated at 80W RMS but I really would only like to install a single 4ch amp to power both the front and rear speakers. I am thinking about getting the PHOENIX GOLD XENON X100.4 so that would be 100W RMS x 4. My question I know that 100W will be lower than the recommendations for the MMC6500 but will 100W be to much for the MMC650 to handle?
I have the following sub : Polk MOMO MM104 and I am pretty sure that I will get the PHOENIX GOLD XENON X400.1 400W RMS to power it.
Any other suggestions would be greatly appreciated.
Post edited by rbarbera75 on
Just looked at PG's specs on those amps... both your choices will do fine. the X400.1 is regulated output, so it'll do 400 into 4, 3, 2, or 1 ohm all the same, which is cool for the one sub. And the 100.4 is also fine for your highs. 100 watts is enough... I used to be an advocate of having a ton of extra power, but what I realized is that you blow a lot of speakers that way. Overpowering is fine sometimes, but you really honestly do not need anything more than 100 w per channel for those speakers considering you only have one sub. it'll blend out real nice with the amps you chose and i think you'll be very happy.The Artist formerly known as PoweredByDodge
I run two PG amps in my truck. Both are Octane series. The 2-channel goes to the MMC6500s and kicks ****. It's clean as far as I can stand it. The monoblock drives a PG ZX 10" sub. I can highly recommend these amps. The Xenons are the series above mine, so even better."SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE" -
Zenon's are the replacements for the Tantrum's I believe (just what i gathered from a few minutes on PG's site). If this is correct, then I fully advocate the Zenons because the Tantrums were excellent amplifiers - EXCELLENT. They were very powerful, very stout, and very reliable. The Octane I was not impressed with at all - I sent two of them back as I was displeased with performance and other things.The Artist formerly known as PoweredByDodge
So far so good with me. I've had ZERO issues with my Octanes or any other PG gear from when I was seriously involved in car audio. As with all gear, there are gonna be bad units, and I don't care what brand it is, they all make a lemon now and then."SOME PEOPLE CALL ME MAURICE,
Actually the Xenon series replaced both the Tantrum AND the Titanium cause they dont make either of them anymore.
I also agree that that amp will work just fine.polkaudio sound quality competitor since 2005
PoweredByDodge wrote:Just looked at PG's specs on those amps... both your choices will do fine. the X400.1 is regulated output, so it'll do 400 into 4, 3, 2, or 1 ohm all the same, which is cool for the one sub. And the 100.4 is also fine for your highs. 100 watts is enough... I used to be an advocate of having a ton of extra power, but what I realized is that you blow a lot of speakers that way. Overpowering is fine sometimes, but you really honestly do not need anything more than 100 w per channel for those speakers considering you only have one sub. it'll blend out real nice with the amps you chose and i think you'll be very happy.Eclipse CD8053
Polk MM6
JL 12w3v2
Polk C400.4 - Actively bi-amping
JL 250/1 -
Underpowering a speaker wont hurt it at all. You feed 100 watts of pure distortion to a speaker capable of handling 150 watts and itll soak it up all day long.
The danger is that by only using 100 watts, youre more likely to push the amp into clipping which then sends out a clipped signal at over 200 watts and thats when the speaker fries.polkaudio sound quality competitor since 2005
MacLeod wrote:Not the danger is that by only using 100 watts, youre more likely to push the amp into clipping which then sends out a clipped signal at over 200 watts and thats when the speaker fries.
Lol - I think that's what ERobinson meant MacLeod the Crime Dog.The Artist formerly known as PoweredByDodge -
I dont get it?polkaudio sound quality competitor since 2005
by blowing speakers by underpowring them - he most likely meant that it leaves people "wanting for more" so they turn up the gains and volume into the clipping range and end up sending dirty signal to speakers and killing them.
and don't you remember McGruff the Crime Dog? well now you're MacLeod the Crime Dog.The Artist formerly known as PoweredByDodge -
Yeah, I get the whole underpowering thing. I dont get how Im the crime dog. Actually Id forgotten all about those commercials. Used to come on during Saturday morning cartoons. Man I miss those cartoons.polkaudio sound quality competitor since 2005
Why not go with the Polk amps?
zgw8 wrote:Why not go with the Polk amps?
i dunno. personal preference? seems like the guy like phoenix gold. its a good company, so i'm not gonna argue with him.The Artist formerly known as PoweredByDodge -
I would have liked to use the Polk amps but I didnt want to have 3 seperate amps in my car, because I want to try to save some weight, not to mention that I did have 3 amps in my old car and it was a pain to mount all three while still having trunk room.
Here is the update on the install, I have everything installed and the PG amps are great and they look good. In my test sheet, one of my amps that was only rated at 400W actually produced 499W, although I could be reading the handwritting wrong but it sure as heck looks like 499W and not 409W.
Now I just need to play with the crossover settings.
Is it best to use the crossovers in the amps or use the headunit for the crossover? -
i prefer to use the crossovers in the amplifiers and avoid using crossovers in the head units. head units usually have 6 db / octave **** grade crossovers and once in a while pre-out voltage will change (specifically older alpines). amplifiers usually have 18 db or greater per octave crossovers.The Artist formerly known as PoweredByDodge
