Tube Tuner Question
sda2mike
sda2mike Posts: 3,131
edited August 2005 in 2 Channel Audio
Since i'll soon be getting a tube pre, i've dug out of storage (actually display) my repaired and fully functional Scott LT 110...this is a great-sounding tuner! however, it needs a good cleaning...whats the best way to go about this job? i've seen some tuner cleaner destroy old components...this one i believe is from the early 60s. after it's all cleaned, i'll get a new faceplate and wood case. thanks! :D
Post edited by sda2mike on
  • dorokusai
    dorokusai Posts: 25,577
    edited August 2005
  • madmax
    madmax Posts: 12,434
    edited August 2005
    It can work but be careful with old PC boards and chemicals. I recommend nothing more than blowing off the boards with canned air.
    madmax
    Vinyl, the final frontier...
  • sda2mike
    edited August 2005
    madmax
    i hear ya...but there seems to be some sort of grime under all the dust..under the grime, the chassis is shiny..
  • madmax
    edited August 2005
    Just test a spot first. My first reciever back in the seventies was cleaned by me. Sprayed the stuff on, used a nice soft brush to gently loosen the grime, another little spray to remove the grime. OH NO! it is still sticky! Got a little more sticky stuff off and found it to be the PCB coming apart. Well, I let it dry and it looked nasty. Worst part is it wouldn't work when I tried it. Oh well...
    madmax
  • sda2mike
    edited August 2005
    scary! the reason i posted this question, i have a scott rcvr i purchased in '83, the last of the heavywieghts. anyway, 1 day i opened it up and went to town with the cleaner..no board breaks, but the tuner no longer tunes :mad: amp still rocks, tho.. maybe i'll just get the wood case for the tube tuner and forget it!
  • PolknPepsi
    PolknPepsi Posts: 781
    edited August 2005
    Hi SDAMike,
    If you are looking for someone to work on your old receiver for you I would recommend Craig at nosvalves.com He works on retro gear and one of these days I would like to buy a nice old integrated or send him one that needs refurbished. My first order of business is to get a tube preamp to go with my S.S. amp just to see what tubes are all about.
    Denon #2900, Denon stereo receiver, Conrad Johnson Sonographe 120 amp, Blue Jeans cables, and Klipsch RF-7's
  • sda2mike
    edited August 2005
    PolknPepsi wrote:
    Hi SDAMike,
    thanks bud!
