Effiency rating?
KrazyMofo24
I have R50's as my fronts and surrounds and a Csi3 as my center. The effiency on the R50's is 89db and on the Csi3 it is 90db. So how many db volume do I need to raise the center channel if any to match the 89db R50's?
Setup:
2 Channel: Vienna Acoustics Mozart Grand, T+A P 1230R, Primare SPA21, Oppo BDP-105
PC: Vienna Acoustics Haydn Grand, Cambridge Azure 650A v2 , Peachtree iDAC, Denon DVD-3800BDCI
Post edited by KrazyMofo24 on
I assume you're talking about setting the levels up in your receiver. I'm not sure, but I would think you'd want to 'turn down' the center by 1db since it's more sensitive. That means it's going to be louder, so I whould think you should turn it down.George Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
opps I misstyped I mean the R50's are 90db and the CSi3 is 89db.Setup:
PC: Vienna Acoustics Haydn Grand, Cambridge Azure 650A v2 , Peachtree iDAC, Denon DVD-3800BDCI -
Do it by ear. Going off the effeceincy rating is not an accurate way to tune the speakers as there are too many variables.
You should be able to tell pretty quickly if the center is too loud.polkaudio sound quality competitor since 2005
Get a SPL meter from Radioshack.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
You can't set things by their specs. The room, placement and general envrionment will change their output and sound. Use an spl meter like this (link) and run a test tone through your speakers setting them all to a consistant level then go from there.
FWIW I've got my CSi3 -1 below the 50s. It's a brighter speaker than the Rs to my ears. Blends better. Set it the way it sounds best to you.
How do you like them so far?
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Oops. Yep, SPL meter. Forgot about that. Doh!!George Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
