1 C400.4 or 2 C300.2?
SamSagaZ
can someone tellme if were better to use 2 300.2 or just 1 400.4?
Post edited by SamSagaZ on
Depends how much power you want to your speakers.Eclipse CD8053
Polk MM6
JL 12w3v2
Polk C400.4 - Actively bi-amping
JL 250/1 -
I would pick the 400.4 simply for the excellent crossover network it has.
The 300.2 is from 50-250 Hz where the 400.4 is variable from 50-5,000 Hz. Much more flexibility with the 400.4.polkaudio sound quality competitor since 2005
mm ok, i just asked that because are like the same price 1 400.4 = 2 300.2...
and for amp the subwoofers?
1 500.1 or 2 300.2?
my subwoofers are an pair of MM2124
and my components mmc6500 -
MacLeod wrote:I would pick the 400.4 simply for the excellent crossover network it has.
I do not know what head unit he is running. So depending on what HU he has the nice crossover network on the 4ch. amp may not be necessary for his setup.
Another thing to consider is ease of installation. Tow amps is easier than the three . This is why I prefer 4ch. amps.Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
well i dont care the installation, i really like hard configurations all these configuration are great to tweak the sound
http://www.pioneeraus.com.au/car_entertainment/cdtuners/dehp8650mp/
its the HU that i have -
For dual MM2124's go with the 500.1. Thatll be around 300 watts to each. Not their max potential but definitely enough to get plenty loud! Besides, another 100 watts to each wont be that much noticeable.polkaudio sound quality competitor since 2005
so for the same amount of money will be better the 500.1
Nice HU! Mine is practically the same.George Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
The 300.2 will overpower a single 2124 so Id play it safe and stick with the 500.1. Plus itll be an easier install.polkaudio sound quality competitor since 2005
ok, looks like 500.1 is the best choice.
ill try to find an cheap price in ebay....
i found a few guys selling that items, but noone have both
in my country i found the 400.4 at 550 U$S and 500.1 530U$S
if i buy it from USA i can save a few bucks -
Ese stereo es muy bueno . I think that if you wanted to run an active front stage, you could do it. It says "3-Way Digital Network selectable". That is a very nice head unit and what ever Polk amps you get will give you a nice setup.
Buena SuerteAlpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin -
hehe, your spanish is good
ok, im trying to find some cheap place/ebay guy to buy the amps, but noone have both models -
well, not lucky finding someone that sell c500.1 and c400.4
JBL GTO601.1 + C400.4?
what do you think guys abt this combo?
someone think that the JBL is like the same as the c500.1?
or the 500.1 is too much better ?
i ask that because i found and seller that have both amps. C400.4 and The JLB. -
for your application, i think the 500.1 is a better choice. you'll get all the power you need and be able to have all your equipment match.
the jbl may be more powerful by a little, but you don't need it, and it'll stick out like a sore thumb.
if you're going to do the JBL then get a JBL 4 channel as well... or do the C400.4 polk and the 500.1 ... tha'ts my opinion.The Artist formerly known as PoweredByDodge -
Mine too. I dont like mixing amps simply cause it looks funky. Plus I think the Polk is a better amp than the JBL.polkaudio sound quality competitor since 2005
ok, ill order just the C400.4.. cant find any seller that have both
someone know some connector that letme COnnect 1 0AWG Input and 2 0AWG Outputs?
wow! thanks a lot dude!
the only problem is that cardomain dont ship outside USA
ill try to find it in another place
Thanks a lot dude
