Which Amp should i use for my MM12
Caliboystyles
Caliboystyles Posts: 5
edited August 2005 in Car Audio & Electronics
Hello,
I have 1 Momo MM12. I am unsure what amp will work nicely with it. I was thinking of the MB Quart Reference RAA1000. Or the Rockford Fosgate 601s. If you have any info on which is better please let me know. Thanks!
Post edited by Caliboystyles on
  • MacLeod
    MacLeod Posts: 14,358
    edited August 2005
    MB Quart is owned by Rockford Fosgate so basically theyre going to be close to the same. Both would be very good.
    Another option is Polk's 300.2. you can get it at Sounddomain.com for $200. It easily makes 450 watts and would be a good match for the MM12.
  • Caliboystyles
    edited August 2005
    Cool, Thanks! So if I decide to go with a mono block MB quart refference, would I use ...250 watts RMS x 1 at 4 ohms or (500 watts x 1 at 2 ohms) ?
  • MacLeod
    edited August 2005
    You wont want to use a Class D amp with the MM12. Its a single 4 ohm voice coil sub so you can only wire it in 4 ohm mono which will only be 250. It would be best to use a 2 channel amp bridged 4 ohms mono.
  • Caliboystyles
    edited August 2005
    Your right, That c300.2 is sweet! I think I will deffinetly go with that, and they will look great together. Thanks again!
  • MacLeod
    edited August 2005
    If you have a Frye's near you, I hear theyre clearing the out at like $100 each. Might be worth checking out if ones near you.
  • Caliboystyles
    edited August 2005
    i have 2 fry's all with a 15 mile radius near by...I'll go there this evening and let you know how it went!
