2 8" vs 1 10" sub
zgw8
zgw8 Posts: 78
edited August 2005 in Car Audio & Electronics
I had to go with two MM2084s vs one MM2104 due to mounting depth restrictions.
Question - how are the two eights going to sound vs one ten? I am running them parallel off of a C500.1
Just got a load of gear. Man are those Polk amps beautifully built!
Regards,
zgw8
Post edited by zgw8 on
  • neomagus00
    neomagus00 Posts: 3,899
    edited August 2005
    yay polk! the 2 8s will perform wonderfully, worry ye not... to set gains, follow this:
    www.andrew.cmu.edu/user/dhuston/gains.html
  • thehaens@cox.net
    thehaens@cox.net Posts: 1,012
    edited August 2005
    Two 8's have more surface than a single 10.............My brother has (8) 6 inch drivers custom mounted in the front (trunk) of his older model 911 and it sounds great. Tight and to the point.........
  • MacLeod
    MacLeod Posts: 14,358
    edited August 2005
    The 10 would play into the lower frequencies better than the 8's. The volume will be the same though.
  • zgw8
    zgw8 Posts: 78
    edited August 2005
    How much better?
    I have a factory JBL system with sub/amp and it is an 8". Junk but better than nothing. The Polk gear is going to be heads above the OEM stuff.
  • MacLeod
    edited August 2005
    I ran an 8 in my Ram for over 2 years. It was an MTX Thunder6000 which is a very good one. I recently got a MM2104 and have noticed not only am I hearing bass notes I never heard before but Im also FEELING bass notes I never felt before. The bass is still very tight and sounds great. Im sold on 10's now.
    I wouldnt sweat it thought. 2 8's will be more surface area and more power than the single 8 I got used to so I dont think it would be that much of a difference.
