Three Rti4's or 4 R15's and 2 Rti4's?
KrazyMofo24
KrazyMofo24 Posts: 1,210
edited August 2005 in Speakers
Would it be better to have 3 Rti 4's as the front and a center? Or should I keep the 2 pairs of R15's I got at fry's $50/pr.
Right now I am using one Rti4 as a center and one as front left, two R15's as front right, and R15's as surrounds.
I have a small room so I dont get much surround effects, would it be better to have a really good 3.1 and cheap Onkyo speakers as surrounds?
Setup:
2 Channel: Vienna Acoustics Mozart Grand, T+A P 1230R, Primare SPA21, Oppo BDP-105
PC: Vienna Acoustics Haydn Grand, Cambridge Azure 650A v2 , Peachtree iDAC, Denon DVD-3800BDCI
Post edited by KrazyMofo24 on
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited August 2005
    I'd keep the RTi4 on the front stage, and get the center to match of use another RTi4 as center. I wouldn't use the R15 as a center with that setup.
    However, the R15 would work find as surrounds. I've used a pair of those for quite a while as surrounds with RTi stuff up front.
  • Willow
    Willow Posts: 11,056
    edited August 2005
    The Rti4's have had great reviews and I have a pair they are great.
  • KrazyMofo24
    edited August 2005
    yeah they do work well as surrounds right now im using one Rti4 as the center and another as front left. Is four R15's worth more then one Rti4 in my situation? obiously im on a budget.
    Setup:
  • MacLeod
    MacLeod Posts: 14,358
    edited August 2005
    Why not get the CSi3 center speaker for $180 and keep those sweet RTi4's on the front and the R's in back?
  • ND13
    ND13 Posts: 7,601
    edited August 2005
    You're using 1 RTi4 as a center and the other as a main, but then 2 R15s as the other main??? :confused: . Why not use the RTi4 that's being used for the center as the other main and use the R15s as the center. Or use one R15 as the front center and the other as a rear center, that is if your receiver supports 6.1.
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • MacLeod
    edited August 2005
    Or no center at all.
    Do you really HAVE to have a center. It seems like Ive heard more negative things about center channels than positive one.
  • aaharvel
    aaharvel Posts: 4,489
    edited August 2005
    exactly. with the csi3 you wouldn't have to worry about off-axis response concerns. They make "center" channel speakers with 2 mid-woofers in the enclosure for a reason.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • KrazyMofo24
    edited August 2005
    If I dont have a center then its just 2 channel right?
    Setup:
  • MacLeod
    edited August 2005
    I went thru this myself when I bought a receiver recently. I already had 2 mains and 2 surrounds from a 2.0 Dolby Surround system. Your receiver gives you the option to select 2,3,4,or 5 speakers. If you choose 4 speakers it will take the signal to the center and divide it up to the 2 mains. This way you can listen to 5.1 with only 4 channels. Its the way Ive been listening to it for a while now.
  • Joey_V
    Joey_V Posts: 8,583
    edited August 2005
    Go with all RTi4s if possible. A good speaker at a good price. Mmmm... mmm!
  • KrazyMofo24
    edited August 2005
    My sister use to work at Fry's and she got someone to give me a discount saved $66 for the Csi3 had to return the R15's, but everything sounds great now.
    Setup:
    VR3 Posts: 28,776
    edited August 2005
    Centers are only required if more people than you watch movies the majority of the time.
  • KrazyMofo24
    edited August 2005
    Yeah, but I noticed when I had the voices going through the left and right took away very noticable details, from the movie like music in the background. Music sounds clearer especially the mids and the highs. I am on the computer when I am playing music, the music doesn't sound like its coming from one speaker anymore.
    Setup:
