Placing external crossovers
dnewhous
dnewhous Posts: 42
edited August 2005 in Car Audio & Electronics
If I were to get a pair of the 5 1/4" MOMOS (not the separate component versions) and try to install them in the front of my Plymouth Voyager, what are the chances I could stuff the external crossovers under the dash panel? (The top dash panel must be removed to install the speakers.)
Daniel L Newhouse
Post edited by dnewhous on
  • 1996blackmax
    1996blackmax Posts: 2,436
    edited August 2005
    Should not be a problem. I am sure that you can find enough room to stuff them in there. Some zip ties would work great to keep them in place.
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
