Q logic or Thunder forms
hrdhtdvr
hrdhtdvr Posts: 103
edited August 2005 in Car Subwoofer Talk
Does anyone have any advice on these two enclosures? I am looking at the vehicle specific (02' Silverado ext. cab) type and am looking for a "Unloaded" version to house my MM 2104 10" sub.
Alpine 9855 hu
Polk/Momo MMC 460 (Rear)
Polk/Momo MMC 6500 (Front)
Polk/Momo MM 2104 Sub
Amp: JL 500/5
Wires: Street Wires
Sat Radio: Sirius PNP
______________________
Home
Kenwood CD 425M 200 disc cd changer
Denon AVR-2801 reciever
Mitsubishi HS-U577
Toshiba -SD1700 DVD player
Klipsch Speakers
Center: RC-7
L&R:KLF-20
Surrounds:RS-3
Sub: KSW-15
Post edited by hrdhtdvr on
  • MacLeod
    MacLeod Posts: 14,358
    edited August 2005
    I would go with MTX over Q Logic. Those seem to be a little more flimsy than the MTX.
    Actually though, your best bet would be to hit your local shop. I bet ya theyve got a good solid, 3/4" MDF boxes thatll fit your truck perfectly and they may even be a little cheaper.
    They had one for my beloved Dodge Ram but it was for dual 10's and I only wanted one. Plus I wanted to build my own.
    VR3 Posts: 29,554
    edited August 2005
    http://www.partsexpress.com/webpage.cfm?&Webpage_ID=3&DID=7&CAT_ID=35&ObjectGroup_ID=144&SO=2&filter=subwoofer&start=1
    High quality enclosures - 1" thick MDF ;) - CNC cut - Wrapped In Carpet... all that.
  • MacLeod
    edited August 2005
    Yeah, but he's looking for a vehicle specific box. Ya know, one thatll drop right in under the seat like it was OEM.
    For those, most manufacturers use plastic as its cheaper than fiberglass.
  • 1996blackmax
    1996blackmax Posts: 2,436
    edited August 2005
    My buddy put a Q-Logic one in his F-150. He has two 8" JL Audio W0's (think), they sound very nice in his truck.
    I myself have had issues with Q-Logic. Mainly leaks with their sealed enclsoures, but nothing a little silicone could not use. If I had a choice I would go with the MTX box too.
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
  • MacLeod
    edited August 2005
    The JL Audio Stealthbox is the best, but its also the most expensive. They dont come unloaded so youre looking at $500 with the sub.
    I still say your best bet is to check with your local shop. Im willing to bet if he doesnt have one premade he can whoop one up for ya in a day or two for less than $200 which is only a tad more than you would pay for a premade box.
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    edited August 2005
    The Stealthbox is fiberglassed over whatever they make the initial molding out of isn't it ??
    I had a thunderform... the one for the dual 10's under the seat of a 94 to 02 ram.
    Now mind you, the mtx 4000's it came with were 200 watt subs, i ripped them out, put in a pair of Polk DX's with about 350 going to each sub (you couldn't buy them unloaded at the time) and i blew a crack in the plastic seam at the back of the plastic piece of crap.
    mtx's response, "the enclosure was not designed for that woofer, warranty void".
    i can respect that... i mean, if i threw an older Momo into a 1/2 " wall particle board box, then i'd be asking for trouble too. I guess the point is though that it's a warning, be careful about buying these plastic hunks of junk, they're not cheap, and they're not very good at all.
    You're better off doing what MacLeod suggests, find a local box builder, give the buy 300 bucks, and call it a day, getting a nice 3/4" mdf or birch ply box that'll last you many many many years, and can take the abuse of 200, 300, 400, 700, 800, or 1000 watt subs should you choose to "upgrade" over time (Assuming box depth is sufficient for the woofer's depth).
    The Artist formerly known as PoweredByDodge
  • 1996blackmax
    edited August 2005
    I wanted to get a JL box for my car, but they don't have them any more :(. They came with one of the older 10" W6's. I still keep my eye open for a used one.
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • MacLeod
    edited August 2005
    Yup, the Stealthbox is made from fiberglass.
  • hrdhtdvr
    hrdhtdvr Posts: 103
    edited August 2005
    Thank you all for the help!!!
    Alpine 9855 hu
    Amp: JL 500/5
    Wires: Street Wires
    Home
    Mitsubishi HS-U577
    Klipsch Speakers
    Center: RC-7
    L&R:KLF-20
    Surrounds:RS-3
    Sub: KSW-15
