weird speaker connectors
danger boy
danger boy Posts: 15,722
edited August 2005 in Electronics
I found this on the bay. some kind of speaker connectors i've never seen before. it is on the rear of a Pioneer SX-6000 receiver. anyone know anything about this type of speaker connector? does it use some kind of plug like a AC type looking unit or what?
PolkFest 2012, who's going>?
Post edited by danger boy on
    F1nut Posts: 51,995
    edited August 2005
    Yep, it's a separate block for each channel with two spades on one side and two screw terminals on the other side. You can buy new ones online for about $5.00 a pop.
  • unc2701
    unc2701 Posts: 3,587
    edited August 2005
    Or if you're of the "cables don't matter" persuasion, you can literally use lamps cords :)
    Backburner:Krell KAV-300i
    F1nut Posts: 51,995
    edited August 2005
    On that gear, it wouldn't make a difference.
