Speaker Specs
hrdhtdvr
hrdhtdvr Posts: 103
edited August 2005 in Speakers
How do I find out what a certain set of speaker's specs are? I am talking about the graph that shows how flat a speaker is so that you may set your cross overs properly. I just purchased a set of 4x6 Polk plate speakers and a pair of 6 1/2 Polk components. On the box, the plates say that they have a range of 73hz-25khz.
The 6.5 components say that they have a range of 43hz to 25khz.\
Does this mean that I could actually set my HU's cross over to say 50hz and not hurt these speakers? I don't have a sub or amp at this time, but will be installing amps for the speakers and the sub that will be going in. I got my equipment from Crutchfield and they sold me a pair of bass blockers at 300hz. Do I need those?
Alpine 9855 hu
Polk/Momo MMC 460 (Rear)
Polk/Momo MMC 6500 (Front)
Polk/Momo MM 2104 Sub
Amp: JL 500/5
Wires: Street Wires
Sat Radio: Sirius PNP
______________________
Home
Kenwood CD 425M 200 disc cd changer
Denon AVR-2801 reciever
Mitsubishi HS-U577
Toshiba -SD1700 DVD player
Klipsch Speakers
Center: RC-7
L&R:KLF-20
Surrounds:RS-3
Sub: KSW-15
  • neomagus00
    neomagus00 Posts: 3,899
    edited August 2005
    i'm assuming you have the components up front. you actually could probably run them with no crossover at all - your headunit doesn't produce enough power to over-excurse them even at 20 Hz. if you feel the need to, feel free to crossover the fronts at 50 Hz. this will change to 80 or 100 or so when you get a sub.
    the rears are a different matter. i would crossover the rears as high as the HU allows. again, it doesn't have the power to hurt those speakers, but the crossover point and the fading from front to rear have a big impact on whole the whole shebang sounds... play around with it, see what you like.
    oh, one last thing - any further discussion should take place in the "car audio and electronics" section, this one is technically for home audio :).
  • hrdhtdvr
    hrdhtdvr Posts: 103
    edited August 2005
    Thanks for the help!
    Alpine 9855 hu
    Amp: JL 500/5
    Wires: Street Wires
    Home
    Mitsubishi HS-U577
    Klipsch Speakers
    Center: RC-7
    L&R:KLF-20
    Surrounds:RS-3
    Sub: KSW-15
  • neomagus00
    edited August 2005
    thank you, thank you, i'll be here till eternity
  • neomagus00
    edited August 2005
    ooh! ooh! that was post 2500! w00t!
