Hum
I have a hum comming from my speaker system !
How do i get rid of it ?
My hole system is made of Polk speakers with a
Denon 1802 receiver.
Hum or Hiss?
Disconnect all video sources, and start adding them back one at time - and you'll find what is causing your ground loop.
Cheers,
Yup, sounds like a cable is a bit out of whack to me.
Russ is right with the fix.There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin -
just in case this ever happens to me, what do you do once you've actually found the source of the noise?It's not good, very fundamentally simply not good. - geolemon
Replace the faulty source component, if it is a IC, if it is a ground loop problem, then you can get an inline isolator to curb the noise. This is probably not the case as from what I can tell you are not running separates. It could be your cable system coming in, in that case you could also get a isolator......This can be extremely frustrating, and can wreck your weekend, especially if you have a ridiculous amount of gear to try and troubleshoot and isolate the problem. I found that it was my parasound amp causing the hum, a difference in potential in all the other components in my line up, is what I gathered. So I got a Jensen Transformer Isolator (Model CI-2RR ), bought more IC's to connect the Isolator, and then I "enjoyed the silence".....
good luck
scott -
A good power supply will fix the power source hum, I'd bet it is in the IC's somewhere. I've had this issue twice, both times it was a bad ICThere is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
