Aiwa TS-WM6
opus
opus Posts: 1,252
Question for you Bass Heads.
In graphing a spl response curve for a friends Aiwa sub I came across some funny numbers. And was wondering if anyone had any ideas about what is happening. I would post the graph but I think I can explain my question without.
The readings from 25 hz and up are pretty standard. Peaks and valleys in the 80 to 95 db range. Not a flat curve but not horrible either. Where it gets weird is the readings from 16 hz, 18 hz, 20 hz and 22 hz. The 16 hz measurement is 100 dbs (corrected). The next 3 readings (18,20,22) fall to 80 dbs.
My question is this: Isn't that a lot of output at a very low freq for a entry level sub? I'm sure I must be missing something, any thoughts would be appreciated.
thanks kevin
The Flea rig
Hitachi 50VG825 LCD
Rotel RSP 1066 (pre) :)-flea market
B&K St-202 (mains)-flea market
Carver M 200t (x2) (center and surrounds)-flea market
Blu-Ray..PS3 (dvd player)
Polk RTA-11t-flea market
LsiC, Fxi30's
Dual SVS PC-Utra's (1 port blocked) thanks MikeC78
Behringer Feedback Destroyer
-flea market
AudioAlchemy DDE v1.0 DAC-flea market
Cambridge Audio Azur 640 CDP-flea market
Signal Cable and Kimber Kable
Post edited by opus on
  • Airplay355
    Airplay355 Posts: 4,298
    edited August 2005
    There's no way your friends Aiwa is doing 16 hz at 80 db. Maybe your mic is **** up, or maybe your correction factor or weighting scale is wrong?
  • opus
    opus Posts: 1,252
    edited August 2005
    355, I didn't think it would be that long before somebody said that. :).
    I know that something ain't right, but just wanted a few ideas as to what that might be. Maybe the rat shack spl meter is cracking up.
    thanks kevin
    The Flea rig
    Hitachi 50VG825 LCD
    LsiC, Fxi30's
    -flea market
  • fireshoes
    fireshoes Posts: 3,167
    edited August 2005
    I'm frankly surprised it plays anything below 40hz.
  • aaharvel
    aaharvel Posts: 4,489
    edited August 2005
    Aiwa. Fancy lights. That's all.
    Airplay's right. The mic's fubared.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
