Crossover install question for civic
mutiny
I bought 690s for my rear deck in my civic coupe and I don't know where I should put my crossovers? Where is the best/easiest place without having to buy any additional stuff? Thanks
Post edited by mutiny on
it doesn't really matter where they go, just find a place where they won't get wet and won't vibrate too much... keeping them away from sources of noise (such as a motorized antenna or the ECU) is a good idea too, but you're in the rear deck, so no biggie...It's not good, very fundamentally simply not good. - geolemon
thanks
any timeIt's not good, very fundamentally simply not good. - geolemon
I stuck mine inside the doors and kept them there for over a year without any problem.
But youre really not supposed to do that. My truck is pretty solid so no water gets inside the door.
I mount my x-over near my amps in the back. Easier tuning that way with everything in the same spot.polkaudio sound quality competitor since 2005
