Svs Pcultra!!!!
Pinktulip7
Pinktulip7 Posts: 249
Wow! excellent Subwoofer but since I connect the Subwoofer with my HK 7300, my T.V. acting real funny,I ment when any kind of special effect appears screen start shaking!!!!!Its become normal after special effect(LFE)gone.
TV :>Panasonic TC-P55VT50
RECEIVER :> HARMAN KARDON AVR 7300
FRONT :> L & R :> POLK RTI A9 500 W
AMP :1> PARASOUND HALO A21 250 W
AMP :2> EMOTIVA UPA-1 200 W
CENTER :> POLK LSiM 706c 250 W
SURROUND SIDE :> POLK RTi A3 150 W
SURROUND REAR :>POLK FXI A6 150 W
DVD PLAYER(HD) :>TOSHIBA HD X-A2
DVD PLAYER(BLU-RAY) :>Panasonic DMP-UB900
POWER CONDITIONER :> PANAMAX M5400-EX
SUBWOOFER :A> SVS SB16-Ultra 1500 W Front
SUBWOOFER :B> SVS SB16-Ultra 1500 W Rear
Post edited by Pinktulip7 on
  • PolkThug
    PolkThug Posts: 7,532
    edited August 2005
    maybe put some vibrapods under the tv.
  • Pinktulip7
    edited August 2005
    TV is on the top of the entertainment center,SVS pcultra is realy very powerfull,its realy shake the whole room.How can I buy Vibrapod?
    VR3 Posts: 29,700
    edited August 2005
    You might try getting a slab for your subwoofer to help contain the vibrations.
    Sorry to hear about your PC Ultra and its power! :p
  • danger boy
    danger boy Posts: 15,722
    edited August 2005
    how close is your SVS to your TV? maybe it's to close. I haven't really heard of this happening much at all. Lots of people in here use SVS subs and have never had this kind of problem.
    Other things to consider... how loud the sub is. are you running it to "hot" meaning way over driven so it's to loud? Is the subwoofer plugged into the same power outlet as your TV? if it is.. you may need to plug it into a different outlet. It may be pulling to much electrical power during those loud passages in the movies.
    PolkFest 2012, who's going>?
  • Toxis
    Toxis Posts: 5,116
    edited August 2005
    You guys understood what he was saying? Impressive...
    VR3 Posts: 29,700
    edited August 2005
    It took some effort. But after reading Ganzo's writing since 2002... :p
  • Early B.
    Early B. Posts: 7,900
    edited August 2005
    Also try turning your sub volume down. You probably have it set to "overkill."
    "God grooves with tubes."
  • Pinktulip7
    edited August 2005
    :eek: SVS PCULTRA is placed in the corner almost four(4')feet away from Entertanment Center where is T.V. been placed.Subwoofer volume in the receiver set to 0 db.And volume in the SUB set to 1/3,I never heard any Subwoofer can possibly sound like this..Its shake the whole room like nothing including my bed!!my friend fell off the bed when one of the special effect in the J.PARK III played.
  • PolknPepsi
    PolknPepsi Posts: 781
    edited August 2005
    Pink T.
    I have the 2039+ and to help it I put 3 spikes on the bottom and set it on square concrete pads from Home Depot. It smoothed things out tremendously and no more excessive house shaking.
    Denon #2900, Denon stereo receiver, Conrad Johnson Sonographe 120 amp, Blue Jeans cables, and Klipsch RF-7's
  • Loud & Clear
    Loud & Clear Posts: 1,538
    edited August 2005
    I'd back the volume off some on your receiver's sub setting. Perhaps -4 or -5.
    You and your buddy should take it easy on that bed.
    Two Channel Setup:
    Speakers: Wharfedale Opus 2-3
    Integrated Amp: Krell S-300i
    DAC: Arcam irDac
    Source: iMac
    Remote Control: iPad Mini
    3.2 Home Theater Setup:
    Fronts: Klipsch RP-160M
    Center: Klipsch RP-160M
    Subwoofer: SVS PB12NSD (X 2)
    AVR: Yamaha Aventage RX-A2030
    Blu Ray: Sony BDP-S790
    TV Source: DirecTV Genie
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited August 2005
    Sony TVs are notorious for shaking picture during bass heavy scenes. My 35 inch model shakes with the CS-350LS on top of it.
  • Pinktulip7
    edited August 2005
    I got CSI5 on the top of the SONY TV,I don't see any logical reason for picture shaking regardless of heavy bass!!!I used different location,different outlet...no improvement at all.. :D
  • Dennis Gardner
    edited August 2005
    I didn't say that there is a logical reason for it to happen. It just does. I searched for help over at AVS forum 2-3 years ago when I noticed the problem and found that Sony tends to have this issue.
    I first noticed it on Eagles HFO bass lines, since they are separated and consistent, it was easy to see what volume it happens at to avoid over driving. I fixed my issue, I went to a smaller system on that TV and installed a front projection HT in another room. :D What a great excuse for an upgrade, huh?
    Just a bad design from the leader in tube TVs.
    DG
  • PolknPepsi
    edited August 2005
    PolknPepsi wrote:
    Pink T.
    I forgot one of the most important parts.....
    About 10 squash balls hot melt glued to the bottom of that concrete pad. The set up really absorbs any un-necessary vibrations of the flooring cabinets etc. etc.
  • BIZILL
    BIZILL Posts: 5,432
    edited August 2005
    dumb question, but..............does it only happen when watching dvd's or regular tv as well?
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • Pinktulip7
    edited August 2005
    Only when I watch DVD movie's...................... :mad:
  • PolkThug
    edited August 2005
    The 'shaky effect' you see on the CRT may be a physiological event. In my old car setup, when the bass would hit, crt monitors that I was looking at outside the car would appear to shake, but the effect was happening with my actual eyes and not the monitor itself. You've got a lot of bass in a tight space, so it could be the same thing.
  • BIZILL
    BIZILL Posts: 5,432
    edited September 2005
    any dumb chance the basswaves are causing dvd player to screw up?
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
  • Airplay355
    Airplay355 Posts: 4,298
    Kinda like sticking a vibrating electric toothbrush in your mouth, kinda shakes the eyes around and makes things you are looking at shake. I think its just **** with your TV though :p
  • beardog03
    beardog03 Posts: 5,550
    My PC-Ultra Rocks the whole damn house..!!
    I love it...
    It doesn`t jiggle the picture on the tv though
    maybe you should sell it to me and get a smaller one... :D
    Or you could go the vibra-pod route under the tv to isolate it from vibrations like they said.... :rolleyes:
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • Pinktulip7
    SVS is the best.....it can kick some serious ****!!!!!!!!!!!!!not only that it can move by himself in a carpeted floor...wowooooooooooooooooooooo
