Amp the mids and highs or no?
drummer81
drummer81 Posts: 20
edited August 2005 in Car Subwoofer Talk
I have four db675's running on an alpine cda9847 that puts out 18 watts rms to each speaker. My plans are to add 1 12" kicker comp dual voice coil in a ported box running at 2 ohms off an alpine 350x1 mono sub amp. As of now, the speakers sound great as is, but i don't want to over power them with a sub. I want clean sound. If I can avoid it, I don't want to amp them. Will I have too?
Post edited by drummer81 on
  • MacLeod
    MacLeod Posts: 14,358
    edited July 2005
    Will you have to? No.
    Will you get the best sound and performance out of them with your head unit? Not even close.
    A head unit is a horrible power source. They only make about 10-12 watts per channel and thats probably at 1% THD. Get an amp. You dont have to get a very expensive one, a $120 Profile would work wonders. I guarantee you that once you amped those speakers you wont believe the difference.
  • 1996blackmax
    1996blackmax Posts: 2,436
    edited July 2005
    Amp those puppies up, you will not be dissapointed :) .
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
  • neomagus00
    neomagus00 Posts: 3,899
    edited August 2005
    ditto - it's quite remarkable the difference that even a small amp can make in clarity of sound, if not necessarily in sheer volume... it will sound much better if the highs can keep up with the bass, which will be difficult to manage from only an HU
  • drummer81
    drummer81 Posts: 20
    edited August 2005
    On a drive this morning I had the windows down and I could notice that an amp would be a must, so if my db's have a rms rating of 60 and a peak of 180, how much should the amp push per channel? I plan to run all four off one amp and with a high-pass filter at 4ohms.
  • CrBoy
    CrBoy Posts: 580
    edited August 2005
    the amp should be able to put out at least 50 RMS per channel...75 rms would be better...
    My $0.02
  • neomagus00
    edited August 2005
    agreed, you want an amp that can make that RMS or above, so you're looking at an amp that does about 75W x 4 Channels @ 4 ohms... strangely enough, polk's own 400.4 fits the bill perfectly :)
  • CrBoy
    CrBoy Posts: 580
    edited August 2005
    Strange isn’t it...?
    :D
  • wlrandall
    wlrandall Posts: 440
    edited August 2005
    My mid/high speakers are two ohm and were killing my HU...bought two of the C300.2s at Fry's fire sale and the results are unbelieveable. Definitely amp them, you won't be sorry.
  • denim
    denim Posts: 79
    edited August 2005
