Speaker Mounts for my LSIFX???
wingnut4772
Ok. I have decided my FXs will have to go up high on my walls so I found some mounts HERE . Should these work do you think? If so, which ones?
Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Post edited by wingnut4772 on
The rear port plate has a keyhole so you can just wall mount them, if you use the proper size screws into studs in the wall. That's what I've done with my LSiFX. Jeff
