Multi-Regional DVD players?!?
PhillyDan1969
I did a search before posting this and didn't find anything...
I have a Denon dvd-2200 and it is capable of playing both PAL and NTSC but I cannot find any information about whether or not it can play multi-regional DVDs.
A friend recently introduced to me Region 3 (asian) limited edition special packaging DVDs and I ordered some simply because they are/look to be incredibly beautiful editions of some wonderful movies (ie. Alien Head "Alien Quadrilogy" DVD set) but the movies are all region 2 or 3 and I need to know if my player will support them. Anyone know or know where I can find the information. Denon's website doesn't seemt to say anything about regional players???
Thanks!!!
Thanks!!!
Denon AVR-3805
Denon DVD-2200
Toshiba DVD SD-3800
Pioneer Laserdisc CLD-S201
Sony Minidisc MDS-JE510
RCA Scenium 61" HDTV
Polk RTi10s
Polk CSi5
Polk RTi6s
Polk FXi3s
SVS PB10-ISD
Post edited by PhillyDan1969 on
Check out this link..........they do codefree installations for you..
Scott
http://www.jvb.nl/jvb.asp?cur=1&level=modifications&page=title&title=652
BTW - I had the same issue with toshiba, they don't offer any region free players here in the U.S. so I went with jvb. You can do the install yourself if you are inclined to do so... -
Check out the Philips DVP 642 dvd player. There is a simple hack using its remote to make it region free and it will play most of the DivX, avi, mpeg file. and the price is also not bad around $60 to $70.
Speakers=>Salk Soundscape 8, Soundscape Center,Surrounds-Dali Rubicon LCR, Lsi7
PreAmp, Amp => Marantz AV8801, ATI 6007 amp, Oppo HA-1 DAC
Source => Sonore MicroRendu, Oppo BDP-103, Mede8er 600XD, Dune HD Smart D1, Synology DS1813+(16TB)
Sub - JTR Captivator S2 (Dual 18")
Power - Furman IT-Ref20i on dedicated 30Amp circuit with Furutech GTX-R outlet
Screen=> JVC RS-45 projector Da-Lite HP 133" 2.35 -
www.videohelp.com Go there and get all the FREE info you need about dvd/cds . LouMy gear,
Acer PH530 720P PJ
100 inch Da-Lite Video Spectra screen
Yamaha HTR 5790
Toshiba HD-A3
Denon 1600 dvd player with sdi out,
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
1 Audiosource amp300 150 wpc Fronts
1 Audiosource ampone bridged 200 watts powering center
1 Onkyo M-282 105 wpc amplifier sides
polk cs400 center
polk RT400 mains
Polk mkII back surrounds,
Polk FX300fxi dipole surrounds
Velodyne DPS-10 sub
Klipsch KSW-10 sub.:cool:
