So much for next week.
swerve
swerve Posts: 1,862
edited August 2005 in Car Audio & Electronics
It's kind of corny because I posted it on bonnevilleclub first and yea... that's not a audio forum.. I left one wire visible for **** and giggles.
Well when I got home today I did the following in the trunk. I'm not sure if this belongs in audio but it contains a ton of pictures!
First are my weapons:
Hifonics XXZeus and Kicker 250.2:
The **** 15"
Distro Block
MDF Floor 2 pieces (shouldn't have to explain what goes where... lol):
XOvers and Wires:
Round Two In Less Than A Minute... Grand Finale with explanation.]
Okay... So basically my amps are mounted in the front while the sub sits in the back.... my xovers are accessible through the passthrough and my distro block is to the left of my box.
I drilled holes under the end caps to the amps and routed the wires under these 2 pieces of the floor. There is plenty of padding//insulation under the boards so i'm not worried about rubbing or anything. here is what it turned out like.
Hifonics hooking up process:
Kicker Hooking up:
Amps hooked up
Distro Block
Random Shots... Playing with lighting:
Hifonics
Kicker
cats.vans.bag...
Post edited by swerve on
  • 1996blackmax
    1996blackmax Posts: 2,436
    edited July 2005
    That is going to be pretty darn loud :) .
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
  • swerve
    swerve Posts: 1,862
    edited July 2005
    I forgot to add... I've had it hooked up for about a month now... just never cleaned it up and took the pictures... i was too ashamed of all my wires strung out.
    cats.vans.bag...
  • 1996blackmax
    edited July 2005
    Looks nice :) .
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • exalted512
    exalted512 Posts: 10,735
    edited July 2005
    are you going to put a cover over the amps so you can carry stuff in the trunk without having to worry about fuggin up the amps?
    -Cody
  • swerve
    swerve Posts: 1,862
    edited July 2005
    -Cody
    you're kidding right? what the hell do i need a trunk for?
    cats.vans.bag...
  • exalted512
    edited July 2005
    to put the dead bodies...duh
    -Cody
  • 1996blackmax
    edited July 2005
    You should get one of those cars from the 70's with the huge trunks.
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • swerve
    swerve Posts: 1,862
    edited July 2005
    -Cody
    psh... you ain't seen my van yet.
    cats.vans.bag...
  • swerve
    swerve Posts: 1,862
    edited August 2005
    Yay for my install.
    cats.vans.bag...
  • neomagus00
    neomagus00 Posts: 3,899
    edited August 2005
    it is rather impressive, the way the ginormous box just blends with the rest of the trunk... then, of course, you see the amps, and sigh and shake your head, and wander off to the nearest pub...
  • swerve
    swerve Posts: 1,862
    edited August 2005
    What the hell is that supposed to mean?! lol
    ahaha :D:D:D:D:D:):):):p:p;);) :rolleyes: :rolleyes: :(:o:o :mad: :D:D:confused::confused: :cool: :cool:
    cats.vans.bag...
  • MacLeod
    MacLeod Posts: 14,358
    edited August 2005
    Pub? Colour?
  • neomagus00
    edited August 2005
    i use words like that specifically to annoy you, you do realise that? :D
  • cam5860
    cam5860 Posts: 632
    edited August 2005
    The install looks pretty clean. I don't know if thats the power wire or rca cables but you need to run that wire under the carpet to that hifonics amp.
  • MacLeod
    edited August 2005
    It works!! :mad:
    :p
  • swerve
    swerve Posts: 1,862
    edited August 2005
    thanks, but it's speaker wire. and it's hidden now.
    cats.vans.bag...
  • exalted512
    edited August 2005
    realise?
  • neomagus00
    edited August 2005
    ditto to you, cept you don't care as much :)
    hey, at least i don't use 'boot' and 'lift' and the like... when i say 'hood', i mean the hood, not the roof...
