Useless tidbits of my plans for next week.
swerve
Well my last day at work is friday... so next week I've decided to finish my trunk.
tonight I hope to tackle making my door panels look a bit better.
then hopefully the trunk will take me 2 days. I have something sweet planned and I'm not going to elaborate.
Also I need to start a simple fiberglass project next week... any info would be appreciated so I can get a good introduction to the concept.... I think there was a tutorial in C&E a few months back so I may try that.
-adam
-adam
cats.vans.bag...
Post edited by swerve on
Try doing a search on here for fiberglassing, cause there is a very good link thats been posted on here quite a few times. My home computer is shot, otherwise I would post the link for you.1993 Ford Ranger super cab:
Pioneer Premier DEH-P880PRS
MB Quart QSD216
in need of amps and subs
Home:
52" Sharp Aquos
PolkAudio Monitor 10's
Harmon Kardon HK3375
Xbox 360
PolkAudio XM tuner
Owner and co-designer of www.basicholdem.com -
Originally posted by neomagus00
http://web.njit.edu/~cas1383/proj/main/cats.vans.bag... -
Thou art welcome, home fry.It's not good, very fundamentally simply not good. - geolemon
But i'm going to hide all my wires in the trunk... i have a MDF floor built right now and i want to raise it a bit to put the wires under and run them up through holes under the amps end caps.
I would like to use like pvc pipe under the floor to make it nice and clean under there incase i have to pull or route any new wires. you think this would rattle (the pvc that is) i have a few layers of carpet and insulation under the MDF floor so I doubt it would rattle against the floor.any input would be greatly appreciated.
-adamcats.vans.bag... -
as long as you damp the pipe somehow, it should be just fine.It's not good, very fundamentally simply not good. - geolemon
neo - your focus with CAR PC is wicked.
you're one sick ****.
I had considered remotely mounting my laptop screen (gut old IBM 760LD laptop, take the screen, run the lines long, mount the screen on the roof with a drop down hinge, do it all clean and ****, and run my own "music keg" - but that laptop is wayyy to old to handle it. its a damn pentium 1
i would suggest only one improvement.
the main power to your computer -- the YELLOW, RED, and BLACK wires coming OUT of hte power supply are simply yellow = 12 volts... red = 5 volts, and black = ground.
you could get rid of the DC to AC transformer, improve efficiency of power usage by about 30 to 40% and reduce AC interference, by simply running all the yellow's to 12 volts (with a 12 volt voltage regulator so it doesn't turn to 14 when the car starts)... the reds to 12 volt (with a 5 volt voltage regulator), and grounds to ground.
"you can do it my son, i have faith in you. wax on, wax off"
i have a AC/DC in my truck for one reason and one reason only -- use of a power drill, dremel multi-tool, angle grinder, soldering iron, laptop, hair dryer, tv/vcr/dvd, etc when in the middle of no where with nothin but my trusty truck and bed fulla power tools - normally i end up forgetting all the power tools though so its completely pointless and serves no use other than for people to be like "what's that little black box?" - and me to be like "baby, you could plug your vibrator in there if you want, its AC power!"The Artist formerly known as PoweredByDodge -
um... you sure you're looking at the right person? i'm fairly confident that i don't own a focus, but i have been known to be wrong about such things...It's not good, very fundamentally simply not good. - geolemon
the back tail lights looked like focus ZX3 lights... but i suppose most hatchbacks look like that... what kinda car is it?The Artist formerly known as PoweredByDodge
my car's a 2000 Saab 9-3 Convertible (Turbo)... it has a ginormous ghetto booty...It's not good, very fundamentally simply not good. - geolemon
LMFAO - ghetto booty, eh? hey, some guy like big girls... not my thang, but to each their own.The Artist formerly known as PoweredByDodge
PBD - that fiberglass tutorial isn't Neo's. Maybe that's where the confusion is coming from.http://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
Alpine 9815
Ascendant Audio Atlas 12
2 Gallons SecondSkin Spectrum V.2 -
ah, i believe that you are right. yes, i don't have dreads. or glassing skillz.
my car is viewable at cardomain if you want to drool at the booty.It's not good, very fundamentally simply not good. - geolemon
Im getting quite a laugh imagining you with dreads.
Where is Sid with his Photo Shop?polkaudio sound quality competitor since 2005
