Tweeters Cracking - Mids just fine. Answers?
Systems
Systems Posts: 14,872
edited August 2005 in Car Audio & Electronics
Can anyone take a guess as to what is going on? I just installed a pair of db6750 components in my 99 Toyota Solara. It originally came with the upgraded JBL system, which to my knowledge is at or above 200 watts. The only modification that I didn't make was I negated to install the Polk supplied crossovers. I did this because I didn't want to cut the factory cables which already were independent of each other at each speaker point. My best guess is that there is already a crossover built into the old JBL system.
Anyway, it already had components in the front doors which were loud as hell. I put the db's in their place and instantly noticed the imporved clairty and increased loudness. However, at higher levels the tweeters start to get a bit distorted. The mids and my 6x9's are running just fine in the back and it never used to do this when I had my JBL's in there.
I find it strange that the tweeters are breaking up a bit and the mids are pounding just fine (actually they don't pump as much as they used to, but I guess that's what you get for improved clarity). Everyone knows that it takes much more power to run a mid sized speaker than it does to run a tweeter. So what gives?
These db's have a higher sensitivity and are running (overall) way louder than my old ones. The only thing I can think of is that there may actually be no crossover at all and unecessary bass is causing the tweeters to work overtime. I do notice some improvement when I roll off the bass and turn it up. Any thoughts guys? Is it possible that I need a more powerful amp? Would a pair of bass blockers solve this problem?
Any help would be greatly appreciated. Thanks.
-Deacon
Testing
Testing
Testing
  • exalted512
    exalted512 Posts: 10,734
    edited July 2005
    its because youre about to blow em because youre not using the supplied crossovers. The crossover frequency is probably much higher for the dbs than your stock ones. Why not run both pieces of speaker wire to the input on the polk crossover??
    -Cody
  • MacLeod
    MacLeod Posts: 14,358
    edited July 2005
    I would quickly install the supplied Polk crossover.
    I doubt the OEM system had a high pass in line somewhere so you may be running that tweeter full range which will quickly kill it.
  • neomagus00
    neomagus00 Posts: 3,899
    edited July 2005
    how are they being powered? stock amplification? if so, dirty power could be your problem...
  • Systems
    edited July 2005
    -Cody
    Damn. This obviously is not a good thing. I've only been running it like this for a couple of weeks so hopefully they aren't spent. So how can I go about doing this without cutting the stock harnesses off? I'm having a hard time finding an aftermarket harness to connect the OEM tweeter harness to the speaker. I basically had to rig the wires in place.
    Do you think the tweeters are ok? Thanks for the replies guys.
    -Deacon
    Testing
    Testing
    Testing
  • exalted512
    edited July 2005
    i would just extend the wires to you can get them both to reach the supplied crossover that came with the polks and put them both to the input, then wire the mids and tweets out of the crossover from there
    and if you havent already, disconnect the tweets. midbasses can play highs without trouble, but bass to a tweeter and its gone
    -Cody
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    edited August 2005
    leave the polk "mid" hooked to the "mid" line from the harness...
    hook the polk "tweet" to the polk crossover... hook the polk crossover to the "tweet" line of the JBL harness. you may have to swap phase if it sounds funny, but that's no sweat (switch + and - wires on the speaker if it doesn't sound right - only on the tweet!)
    this will increase your crossover slope by either 6, or 12 db's most likely. this will not harm your speakers, but may make the transition from woof to tweet a bit more sharp. but if your stock JBL system is amped AFTER internal crossover, it's probably your only option.
    more information would be useful...
    -vinnie.
    The Artist formerly known as PoweredByDodge
