Goldring 1042 Cartridge
madmax
madmax Posts: 12,434
edited August 2005 in Flea Market
Goldring 1042 phono cartridge for sale. I estimate about 250 hours of use. It should have about 1350 hours left on it. This cartridge has a very flat frequency range and is considered an extremely good cartridge for its price range.
This cartridge sells for $335 new on the internet. I have the plasic enclosure it came in, box and paperwork which I will include. I am upgrading to a much better cartridge. $$$$:D
Here is a reference to it: http://www.needledoctor.com/s.nl/sc.2/category.1058/it.A/id.241/.f
$150 shipped!
EDIT: Last chance offering. PRICE HAS BEEN SLASHED TO $100 SHIPPED!
madmax
Vinyl, the final frontier...
Post edited by madmax on
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited July 2005
    You must have gotten that little wiggle issue corrected.
  • madmax
    edited July 2005
    Yep. Someone suggested I ran across a few records which just happened to have the hole off centered. They were correct. Saved me about $350 for a new bearing!
    madmax
    By the way, this is what I'm replacing the Goldring with. :D
    http://store.acousticsounds.com/browse_detail.cfm?Title_ID=11086
    It is a little too much cartridge for my phono preamp but in the future I'll upgrade.
  • Polkersince85
    edited July 2005
    Nice. If it's performance matches more expensive carts, why spend the other 3K.
  • madmax
    edited July 2005
    The 1040 is considered better than many in its own price range, not in a different class. Is it as good as any of the $750 dollar ones, maybe. At least you could talk yourself into it. Lets face it, a $50, $150, $350, $750, $1500, $3000, $7000 and $12000 cartridge will all sound different. It starts getting "magical" beyond the $1K mark as far as I can tell.
    I heard a Benz Micro at a fellow audiophiles home and it blew me away. I still remember the sound. It was magical. By magical I mean I could almost see the sounds dancing around in front of me. It was different for sure. Almost animated. I figure next year I will no longer remember the cash outlay but will still have the sound, hopefully. Besides, I got a good deal. :)
    Of course next year sometime I will have to upgrade the preamp to something more reasonable to enjoy the information extracted by the cartridge.
    madmax
  • Soccerplyr
    Soccerplyr Posts: 160
    edited July 2005
    If I can find someone to fix my Dual 604 (audio very faint in left channel) i would be interested.
    Pioneer Elite VSX-21TXH
    Monolith 7x200 Amplifier
    Harmony Hub
    Sony VLP-HW40ES
    Visualapex 106" Electric Screen
    Oppo BDP-103
    Music Hall MMF 2.1
    Polk LSiM 705
    Polk LSiM704c
    Polk LSiM702F/X
    SVS PB-2000
  • madmax
    edited July 2005
    Good luck with the fix!
    madmax
    Here is a repair manual for your table: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=5791142293&category=48649&ssPageName=WDVW&rd=1
  • Spawndn72
    Spawndn72 Posts: 453
    edited July 2005
    If the 604 is anything like my 704 there is almost nothing in the table itself that could be casuing a faint channel. It is pretty much a striaght shot wire from the cart to the rca plugs. There is one disconnect in between, but it would not cause a faint channel. It would either be working, or not working. One thing you can try is to clean the contact points where the cart holder comes into contact with the head. I used a pen applicator of de-oxit on mine. Fixed my problem right away. Mine was intermentent sound coming from the channels. The other thing to check is the cart itself. Try a different cart. I bet it is either the cart or dirty contacts.
    Hope that helps,
    Todd
    Setup:
    Adcom GFA-545 amp
    Nad 1600 pre
    Dual 704 TT
    Pioneer 707 R2R
    Pioneer DV-578A Multi-format
    Polk SDA-2 Mains
  • madmax
    edited July 2005
    Shameless bump. :)
  • madmax
    edited August 2005
    madmax
  • madmax
    edited August 2005
    Sold!
    Thanks,
    Chuck
  • fireshoes
    fireshoes Posts: 3,167
    edited August 2005
    Thanks, Chuck, it arrived today and I am just about ready to take her for a test drive!
  • cmy330go
    cmy330go Posts: 2,341
    edited August 2005
    Hey Bob! You putting that on your tech???
    HT
    Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
    2 CH
    Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
  • fireshoes
    edited August 2005
    Nope, I got a Pioneer PL-L800 from dorokusai probably 4 or 5 months ago. Do a search in the flea market.
