LHS Infinity System
Systems
Systems Posts: 14,873
edited July 2005 in Car Audio & Electronics
I have a 1999 Chrysler LHS with the Infinity System. I have blow the front center speaker and the door speaker (not the tweeter) Have been told that the speakers a 2ohm and that 4ohm would not work. Does anyone know for sure and does Polk make a replacement part?
Testing
Testing
Testing
  • neomagus00
    neomagus00 Posts: 3,899
    edited July 2005
    there should be no reason a 4-ohm speaker wouldn't work, it just would be half as loud as the 2-ohm speakers, and thus sound very odd. polk doesn't make drop-in single-speaker replacements, but you can upgrade to a polk coaxial or component set (this is what i'd reccommend, because you seem to already have tweeter spots)... interested in knowing more?
  • Systems
    edited July 2005
    Yes, I would like to know more. I am interested in replacing the 6 3/4" door speakers and possibly the small tweeters near the windows. Does Polk have 2ohm speakers?
    Testing
    Testing
    Testing
  • Systems
    edited July 2005
    Should have mentioned that the door speakers and the near window speakers are a component set. If I were to swap those 2ohm parts out with 4 ohm parts how would that sound? Would my rear speakers be considerably louder than the fronts?
    Testing
    Testing
    Testing
  • neomagus00
    edited July 2005
    well, swapping out the speakers for a new component set like the mmc6500 would necessitate a new amplifier, so you wouldn't have to worry about how loud the rear speakers are - the fronts would be way louder, even though they are 4 ohms.
    polk does not make a 2-ohm speaker that i know of.
    you would want to replace the midranges and the tweeters at the same time - it would sound very odd to have mids and tweets from different people, they're very carefully designed to work with each other.
    what kind of budget are you looking at?
  • exalted512
    exalted512 Posts: 10,735
    edited July 2005
    if you just want a replacement, what i would do is go ahead and replace both mids instead of just one. Just go to partsexpress and get a couple from there. I'm sure you'll be able to find some 2 ohm speakers.
    -Cody
