to loud?
tecmo04
just out of curiosity how do you know if your running your amp/subs to hard? are there tell tale signs that i can listen for? basiclly i dotn want to blow or fry my amp/subs and im trying to be proactive....
Post edited by tecmo04 on
you hear distortion if you're running too hard. distortion in a sub manifests itself as a buzzing or straining sound in a test tone... in normal music, it's sound like a 'whoomp' or 'pop' where there shouldn't be one... if you want to be sure you're not overdriving anything in your system, go nyah for a walkthrough on setting your gains.
and congratulations on being one of the rare few that actually cares about overdriving your equipment...It's not good, very fundamentally simply not good. - geolemon
the main reasoni ask is because when i drive my car i can not hear any problems with the ssubs realy (other than the rattles coming from my car). but when i open the trunk to listen to them its a whole nother story. I dont like what i hear at all.
BTW i am running 2 MM2124 off the Sony Xm-d400p5. I mean i dont think i can over drive subs with the amp. should i be worried about frying the amp, i have it turned up almost all the way right now... -
then hell yes you are overdriving it! follow that link, do what it says, and you and your equipment will be much much happier... rarely does gain need to be set above about two o'clockIt's not good, very fundamentally simply not good. - geolemon
dood.. who cares.. just crank the gains and the bass boost... cruise around and pickup all the ladies cuz you got louder bass than all the otha playas...
but seriously....
Turn yo Ish down son... your fenna be blowin somethin and it ain't no light bulb.cats.vans.bag... -
ok i read the articele, good read. the one dispute i have with it is that i still ahve my stock HU. which means i ont have a seperate sub volume control. i normaly keep the stock electric POS equilizer it comes with around half the dots (for the bass) so i dont think the bass is realy that loud.
another question, i do primarily listen to rap and techno, so where can i find a 20-40htz tone so i can tune my subs?
the funny thing is when i had my amp volume at about half the subs sounded decent, now that i have it up almost all the way (probably somewhere beween 85-90%) i think they sound cleaner and hit harder.
one last thought, if the amp volume is realy high, but my bass is turned down alot at the HU do i still risk detroying my equipment?
again thanks for all the help neo -
the stock HU is what's keeping you back. You gain should not be all the way up...Originally posted by tecmo04
again thanks for all the help neocats.vans.bag... -
the 'amp volume' you're talking about is called the gain, and its function is to match the amp to the voltage it's recieving. maximum gain generally corresponds to a voltage of about .8V, and you're probably running about 6V. so, at any volume level over about 1/5, you're clipping the amp. yes, it will be louder, but it will also be more distorted, and i'm actually rather surprised that something hasn't died yet.
in the attached file you will find a 27 Hz sine wave in a zip, which should be good for you. the zip is very small, the .wav is about 100 times larger - repeating patterns compress very well
as a note, you don't need a sub control on your HU, you'll put all the equaliser settings at flat, which means either zero or midway, depending on your particular eq.It's not good, very fundamentally simply not good. - geolemon
ill go turn it down after work. but that means im goign to turn up the bass on the HU. I know the stock HU is holding me back but unfortunatly i have a 99 sable with digital climate controls. this means i can not replace my HU or if i could it wouldnt be worth the cost. Any other recomondations on how to get the most performance out my system with out being worried about damaging it (obviously)?
again thanks for the speedy responses neo, uve been a great help and my car thanks you... -
if you turn down the amp and turn up the bass, you've created the same problem in a different location. really - follow the tutorial, and if you find that your level of bass is still unsatisfactory, you need bigger and better equipment. or at least major tweaking of what you have now. sucks, i know, but it's much better to deal with less bass now and buy new stuff when you're ready than to kill your equipment (and therefore, concievably, your car, though this is rather rare) and have to go completely without.
and yes, if you read it through a couple times, that sentence is correct
. It's not good, very fundamentally simply not good. - geolemon
thanks for all the help neo. one more quick thing, where can i ge a test tone to calaborate my amp?
