Suggested Surround Speakers.....
Putting together a HT system and have all components except the surround speakers. I am leaning toward the FXi3 using the "dipole" sound pattern - installed on the side of the room.
My question is, having the following RM7302(center), RM7300(left-right) is the FXi3 a good match? I truly believe after reading about Bi-Pole/Di-Pole this "type" of speaker would be the "best" for my application.
Finally, if I decide to install a 6.1 or 7.1 setup, what are people's opinion on a rear speaker choice? Could I just get away with 6.1 or would I be missing out not having that last speaker in the 7.1 set-up?
I appreciate any information and thank you sincerely for all the information I have gathered so far from this forum!
- Marty
- Marty
Work in progress.....
POLK ~ RM7302
POLK ~ RM7300
ASCEND ACOUSTICS ~ HSU VTF-2 MK 2
HARMAN KARDON ~ DPR2005
SONY ~ KDE-50XS955
POLK ~ RM7302
POLK ~ RM7300
SONY ~ KDE-50XS955
not sure on how rm's would match up with fxi3's. Aren't RTI's/FXi's nicer speakers than RM's?
If you have a 5.1 setup- I recommend Dipoles on the sides.
If you have a 7.1 setup- I recommend Bipoles on the sides AND rears. -
Originally posted by aaharvel
not sure on how rm's would match up with fxi3's. Aren't RTI's/FXi's nicer speakers than RM's?-
Thanks for the response. I bought the RM7300 & RM7302 for the mere fact I was looking for a wall mounted speaker. I was sold on their sound, price point and well - they are going to look sweet nestled next to the 50" WEGA.
I would have stuck with the RM series surrounds but Polk does not offer any with the bipole/dipole design.
Now with that said, if i decide to build out a 6.1 or 7.1 could I perhaps use the FXi3/5 with the dipole setting for the side surrounds and use the RM6901 for the rear surrounds?
- Marty
POLK ~ RM7302
POLK ~ RM7300
SONY ~ KDE-50XS955 -
absolutely. if you're system is based on movies only i recommend dipole side and bipole/monopole rear.
But I still recommend Bipoles all the way around if your system is music/movies.
