LSiC issue
I just bought LSi15's with the LSiFX and LSiC and paired them with a new Denon 3805. First off it sounds amazing. I'm not used to the frequencies that I'm hearing now
. The issue is the left midrange speaker on the LSiC isn't making any noise at all. Well, it acts more like a passive radiator than a speaker and it definitely doesn't sound like the other midrange speaker. At first I thought maybe it's because of a crossover or something, but now I'm thinking it's somehow unhooked itself. Can I open it without **** up the warranty? What do you think?
Denon 3805S
Denon 3910S
Polk LSi 15's
Polk LSi F/X's
Polk LSi C
Boston Pro 10" DIY Sub
Samsung 5678W DLP 1080P
PS3
Denon 3910S
Polk LSi 15's
Polk LSi F/X's
Polk LSi C
PS3
Post edited by RoosterD on
Cascaded Tapered Arrays -
http://www.polkaudio.com/home/technology/cascade.php?category=21&speaker=162
LSiC - Read Up
http://www.polkaudio.com/home/products.php?category=5&speaker=162
You should know every speaker you own top to bottom. The design, and specs of it should be understood. Just a IMO. The technology Polk uses is interesting if you just get your read on.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
LSiC - Read Up
Thank you, I stand corrected. I did read up on every little bit, I just didn't understand the 2nd url you listed there when I read it the first time. Thanks again.Denon 3805S
Denon 3910S
Polk LSi 15's
Polk LSi F/X's
Polk LSi C
PS3 -
No problem.
Polk puts alot of engineering in their products. Lots of weird technologies...
The 2nd link is the LSiC's write up page, it gives you all the details Polk wants you to know about.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
You may want to get a 2 channel amp of at least 200w@4 ohms if you want to listen to things loudly. The 3805 will hold out decently on the other speakers, but the 15's passive subwoofer will really tax the Denon.Dodd Audio ELP [ Tubes ] // Harman Kardon AVR330 // Parasound HCA-1203A // Denon DVD-2900
Polk Audio LSi9, LSiC, LSi 7 // HSU STF-2 // Signal Cable Interconnects (SG BW/A2/MP) -
A nice pair of Outlaw monoblocks will do the trickReceiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
Rear Surrounds: polk R20
Subwoofer: polk PSW404
DVD: Panasonic DVD-S29
