Just purchased Monitor 7's Upgrade suggestions?
shanedrew
shanedrew Posts: 84
edited July 2005 in Vintage Speakers
I just purchased these and they are on the way. Bought them off of Audiogon. Any suggestions on upgrading them (Tweeter's Crossover's or anything else). I will include a link to them so someone may be able to tell which version these are. I think there was an a, b and c model. Any insight would be great!
http://cls.audiogon.com/cgi-bin/cls.pl?spkrmoni&1126444981
Post edited by shanedrew on
    SCompRacer Posts: 8,511
    edited July 2005
    Welcome to the forum shanedrew.
    They look to be in nice shape. I like Oak.
    I don't know much about Monitors, other than the tweeters look like the SL2000's in my SDA's. According to the parts list, 7C's came with SL2000 tweeters. There is a replacement for that tweeter that isn't as bright sounding. Depends on what you like though.
  • shanedrew
    shanedrew Posts: 84
    edited July 2005
    The tweeter you are speaking of, is it the silk one? I prefer the silk over the harddome. Thanks for the reply
  • Loud & Clear
    Loud & Clear Posts: 1,538
    edited July 2005
    Yeah, you can easily replace those with the new silk tweeters. I'd also make sure the seal is nice and tight if it isn't already.
    Two Channel Setup:
    Speakers: Wharfedale Opus 2-3
    Integrated Amp: Krell S-300i
    DAC: Arcam irDac
    Source: iMac
    Remote Control: iPad Mini
    3.2 Home Theater Setup:
    Fronts: Klipsch RP-160M
    Center: Klipsch RP-160M
    Subwoofer: SVS PB12NSD (X 2)
    AVR: Yamaha Aventage RX-A2030
    Blu Ray: Sony BDP-S790
    TV Source: DirecTV Genie
