Voice coils
carney115
carney115 Posts: 32
edited July 2005 in Car Subwoofer Talk
Can anyone explain the difference between a sub with a single voice coil and one with dual vc's? My current polk dx12 has a single voice coil i believe. Will upgrading to a dual voice coil sub greatly improve the sound quality?
Kevin
Post edited by carney115 on
  • spwuinmk67
    spwuinmk67 Posts: 797
    edited July 2005
    A DVC sub simply allows more wiring options, so you can get more power out of your amp, if both are capable of handling the power. The same sub, in DVC or SVC will not sound different.
    1993 Ford Ranger super cab:
    Pioneer Premier DEH-P880PRS
    MB Quart QSD216
    in need of amps and subs
    Home:
    52" Sharp Aquos
    PolkAudio Monitor 10's
    Harmon Kardon HK3375
    Xbox 360
    PolkAudio XM tuner
    Owner and co-designer of www.basicholdem.com
  • MacLeod
    MacLeod Posts: 14,358
    edited July 2005
    Most sub amps are Class D mono amps that can run at 2 ohms mono. You cant get a 2 ohm mono load out of a normal SVC sub so manufacturers came out with the DVC model. Like SP said, it gives you more flexibility in wiring and thats it. No difference in SQ.
