Recalculating my output
ode
I am using 8 ohm speakers on an AV receiver that is designed for 6 ohm speakers. If it is 80 watts per channel at 6 ohms do i have enough power with the 8 ohm speakers? How can I calculate that?
Post edited by ode on
You are fine. The lower the ohm the speak is rated at, the more power you need to drive it. In reverse higher ohm= less power to drive the speak.RTi10
CSi5
RTi28
SVS PB12-ISD2
Denon 2106(pre/pro)
Adcom 5503(200x3)
Audioquest Diamondback ICS
Kimber Kable 8tc biwire(mains and center)
"Don't let your silly dreams fall in between the crack of the bed and the wall."
-J. James -
OK ty
You mean higher impedance (higher amount of ohms), less amount of current.... lower impedance, more amount of current.
Making a lot of assumptions, driving a 4 ohm speaker with 50W and a 6 ohm speaker with 50W would, in theory, give you the same amount of loudness (dB's).
Ode - assuming you have a typical receiver, you'll have less power with the 8 ohm speakers. Whether you have enough power or not will come with listening and seeing if you have any noticeable distortion at your listening level.Brian Knauss
ex-Electrical Engineer for Polk -
Well my receiver is 80 wpc driving 4 R50's. Right now it's hard to tell in a movie because I have a POS little sony center but I just bought a CS1 which should be a better match with the R50's. Once it arrives and I have it set up I'll know if I need more juice.
