Tweeter Distortion
nellis8166
I usually hang out in the home theater forums, but I need some help with my car audio.
I installed siruis sat. radio a couple of days ago but I am having some issues with the sound. There is a annoying distorted almost crackling type noise coming out of my tweeters. It is only with the sat. radio. Normal radio and cd's are fine. Any feedback would be appreciated. Thanks.
-Nat
-Nat
RTi10
CSi5
RTi28
SVS PB12-ISD2
Denon 2106(pre/pro)
Adcom 5503(200x3)
Audioquest Diamondback ICS
Kimber Kable 8tc biwire(mains and center)
"Don't let your silly dreams fall in between the crack of the bed and the wall."
-J. James
CSi5
RTi28
SVS PB12-ISD2
Denon 2106(pre/pro)
Adcom 5503(200x3)
-J. James
Post edited by nellis8166 on
if it only happens with the sat radio...then it has to do with that unit...the connection...or possibly the hu/sat section on the radio.
What unit(s) did you add. what kind of connections. Details will help us figure it out. -
Thanks for the help. I have a Starmate ST-1. I just have it running via the wireless FM transmitter into my h/u. I have a feeling this may be the issue.RTi10
CSi5
RTi28
SVS PB12-ISD2
Denon 2106(pre/pro)
Adcom 5503(200x3)
-J. James -
I was just about to ask if youre running wireless. Those things are just not trustworthy in my opinion and can let in a lot of noise.
My guess is that is your problem.polkaudio sound quality competitor since 2005
Good call MacLeod.
I know a few people that have had noise issues with the wireless devices in their cars.Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
Is there anyway to hard wire it into my stock Infinity h/u? I drive a 2004 Mits. Eclipse GTS. It has the upgraded Infinity sound package. I hate to ask stupid questions but I'm a novice in the car audio area. Thanks for the help.RTi10
CSi5
RTi28
SVS PB12-ISD2
Denon 2106(pre/pro)
Adcom 5503(200x3)
-J. James -
The starmate fm transmiter isnt all that bad actually. One of the better ones in my opinion. I sell them all day long, and bought one for my dad. Try changing the station that it sends the signal on, that might help as well.1993 Ford Ranger super cab:
Pioneer Premier DEH-P880PRS
MB Quart QSD216
in need of amps and subs
Home:
52" Sharp Aquos
PolkAudio Monitor 10's
Harmon Kardon HK3375
Xbox 360
PolkAudio XM tuner
Owner and co-designer of www.basicholdem.com -
Check out this website HERE . If they don't have anything, nobody will. The link is an application guide. Look at the Chrysler listing or call if you're not sure. At the bottom of the PDF, look at the notes for Chrysler to determine if your HU will work. If you have a changer, you'll lose that function. HERE is the main site.
From the way it looks, you would have to get another Sirius tuner. One that has RCA outputs.
HERE is one. It's a little pricey, but a nice piece. -
The model he has has outputs. Just pick up a cable that goes from 1/8" stereo jack to RCA's. Anywhere from $7 to $30 at radioshack.1993 Ford Ranger super cab:
MB Quart QSD216
Home:
52" Sharp Aquos
Xbox 360
PolkAudio XM tuner
I hate to beat a dead horse here but my issue is I don't know if my h/u has outputs on it so I can just run a simple rca cable. I've looked everywhere for specs on it but have come up empty. Any ideas short of pulling the h/u would be great.
CSi5
RTi28
SVS PB12-ISD2
Denon 2106(pre/pro)
Adcom 5503(200x3)
-J. James -
i highly doubt that your stock hu has preouts... but i believe the RCA suggestion was meant to run rcas from your tuner... i'm not terribly familiar with your type of setup, but it's worth a lookIt's not good, very fundamentally simply not good. - geolemon
why not buy a modulator and wire it in... so it's not wireless?cats.vans.bag...
You beat me to it. -
Originally posted by PolkThug
You beat me to it.cats.vans.bag... -
Modulator??? What. I'm clueless when it comes to car audio. Can someone post a weblink???
-NRTi10
CSi5
RTi28
SVS PB12-ISD2
Denon 2106(pre/pro)
Adcom 5503(200x3)
-J. James
