Acoustically Dead Room????
BrentMcGhee
Is a room that is totally acoustically dead the best enviroment for surround sound?
From what I read this is true.
The only sound you want to hear is what is comming out of your speakers and not what is comming back after bouncing off walls.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
I believe an acoustically dead room is not what you want because its not what we are used to in the real world.
HBomb
no spell check:p***WAREMTAE*** -
I think you'd have to hear one and decided for yourself- they really **** with you and are kind disorienting. Your first reaction is to think that your ears are stuffed with cotton- there are zero reflections, which can somehow make it harder to pinpoint sounds... very weird experience...
Anyhow, I would guess that you could design speakers for a room for like that, but you wouldn't want to use stock stuff- everything has relfections in mind. Dipole speakers would go from cool and enveloping to crappy-and-off-axis-times-2.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
I agree acoustically dead rooms are not the best environment, although some sound absorption is a good thing to prevent too much brightness and reflectiveness. A dead room would need fairly forward sounding speakers and a powerful amp to achieve good results.Current System:
CSi5-Center (for sale**)
FXi3-surrounds (for sale**)
Martin Logan Depth-Sub
B&K AVR 507
Pimare CD21-CD Player
Denon 1815-DVD Player
Panamax M5500-EX-Line Conditioner -
No!:eek: Definately not.
Have a look at these articles at Harman International. This is a great place to start on acoustics. Do some searches for more information. -
I've done some work for a local audiologist in the past, and I went into one of his "isolation chambers". It is EXTREMELY creepy... You feel like you're deaf if you don't keep talking or making some sort of noise. It's very odd.Ludicrous gibs!
Sounds like a fun experience...lol.
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
They call them SDAs.
You wouldn't have to worry about them being cornered for a change. You would actually get the low frequency gain that corners provide without the high frequency reflections that eff up the SDA soundstage.
Now I wonder if I quilted all the side walls.....................HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
yeah but with surround sound arnt all of the reflections and reverb already encoded into the soundtrack and therfore with all of the speakers suround you couldnt they emulate any type of enviroment?
I have a fairly dead room. It will show any and all faults with your audio system. Now keep in mind, this is not nearly as dead as one of the chambers. To keep your sanity you need a little bit of reflection otherwise you will end up hating everything about your system that is not absolutely perfect. I think the perfect balance is to put together the best system you can then deaden the room to the point where you start hearing the inadequacies of your system.
Will an acoustically dead room get rid of the ringing in my ears from listening to music too loudly?
Nope, but not playing music as loud won't let it happen
Hi Brent,
It is true that acoustics in a home theater should be deader than for 2-channel listening, but a totally dead room is not what professional theater designers shoot for.
The Reverberation Time, which can be used as a measure of how dead a room is, is the amount of time required for an impulse sound to die down to a millionth of it's original level. The Reverberation Time for a typical sized home theater should be in the 250-300 ms range.
Larry -
Thanks Larry, I am asking because i have the chance right now to build a theater room from scratch and right now i am looking into acoustics aspect of it.
Hi Brent,
Here's a resource tha may help you:
Master Handbook of Acoustics
This Internet forum specializes in designing home theaters:
Dedicated Theater Design & Construction
Larry -
Brent. When I was making the acoustic panels for my HT room, I did alot of experimenting with various types of panels. I once had my room so dead sounding that it seemed eerie. Unfortunatly, I didn't have the right gear to test with, so it was trial and error. I used absorptive around the front and reflective/absorptive in the rear. I have yet to install diffusive panels. As I am sure they would help.
