12 O'clock
Willow
Willow Posts: 11,231
edited July 2005 in Electronics
I read alot that we should not go past 12 on the receiver. Well If I do that I am bearly at -60 on my receiver and I can only watch TV at that volume and just hear what they are saying. So what is with this 12 positioning all about ?
Post edited by Willow on
  • Mike682
    Mike682 Posts: 2,074
    edited July 2005
    Willow,
    Here's a good explanation from Outlaw's FAQ section:
    Volume Control on the Model 1050
    The Outlaws
    "Why do I have to turn the 1050 volume up so high?"
    The Model 1050 uses a linear volume control. You will find 54-60 on the dial to be average listening. Most people are more accustomed to logarithmic volume controls. This type typically outputs 90% if its power capabilities by 11:00 on the dial! This is not the case with linear controls. They offer greater accuracy in setting the desired level, and use virtually all of its volume range.
    Receiver: harmankardon AVR235
    Mains: polk R30
    Center: polk CSi3
    Rear Surrounds: polk R20
    Subwoofer: polk PSW404
    DVD: Panasonic DVD-S29
    VR3 Posts: 29,427
    edited July 2005
    *sigh*...
    Subject is getting old.
    ZERO on a modern, linear scale receiver - is 12 OCLOCK.
    Zero, 12 Oclock = Reference Level
    Just turn it up to zero and report back to us. You will experience reference level and 12 oclock at the same time. Its a great experience on dynamic recordings. Really.
  • Willow
    edited July 2005
    it may be to some one who has 8K + posts.
    But thanks for the answer I was just reading the polks Q&A's and saw this I remembered reading the answer somewhere but couldn't find it so I thought I'd ask.
    F1nut Posts: 51,771
    edited July 2005
    That really depends on the gear and is not a guideline one should follow.
    VR3 Posts: 29,427
    edited July 2005
    In general, zero on a linear volume control is reference level.
    Reference level is where the amplifier is giving ALL it has to the passage.
    Yes, sometimes a recording may be toned down, while others are amped up.
    There are way to many variables to consider. But in a perfect world. Zero is your friend.
    Which you have obviously found Mr. 130 db! ;):p
