Domus anyone?
polkatese
polkatese Posts: 6,767
edited July 2005 in Speakers
She's coming to your nearest dealer this month. Has anyone check her out?
I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
Post edited by polkatese on
  • ohskigod
    ohskigod Posts: 6,502
    edited July 2005
    that tweet looks familiar, is that the Vifa?
    how much are those things, i must admit, they look pretty cool.
    Living Room 2 Channel -
    Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
    Upstairs 2 Channel Rig -
    Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
    Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites
  • Early B.
    Early B. Posts: 7,900
    edited July 2005
    Got any specs on 'em?
    "God grooves with tubes."
  • polkatese
    edited July 2005
    System Type: 3-way, front reflex port
    Cabinet: Lute-shaped design and construction with de-coupled side panels
    for resonance control
    Tweeter: 1 in. ring radiator, magnetically shielded custom designed ultra dynamic linearity driver
    Midrange: 6 in. paper-coated cone, magnetically shielded, custom designed, compression free driver
    Woofers: 7 in. paper-coated cone, magnetically shielded, custom designed, compression free driver
    Crossover: Crossover points 400Hz and 3.6kHz initial first order, distributed multi-slope, optimized phase characteristics for correct space/time performance.
    Frequency Response: 30Hz - 20kHz, tuning port included
    Sensitivity: 90dB SPL (2.83V/1m)
    Nominal Impendance: 4 ohms
    Power Handling: 30-200W without clipping
    Finish: Combination of black leather and teak or black piano lacquer
    Dimensions: 8.25 x 12.25 x 41.75 in (WHD)
    205 x 310 x 1060 mm (WDH)
    Weight: 114.75 lbs per pair – net / 132.5 lbs per pair - shipping
    52 Kg per pair – net / 60 Kg per pair – shipping
    msrp: $6,000 - Street: $4,000
    www.sumikoaudio.net
