Tube speakers anyone?
Check these out...
HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
Post edited by Early B. on
Here are the specs...
Pure Vacuum Tube Amplifier (Tube Model: 6F2 x 1 6p1 x 2/Each one)
Output Power: 8W/Each (Max.:10W)
Frequency response: 20Hz~30KHz (1w Output)30Hz~18KHz(5w Output)
S/N: 86dB (A-Weight)
Net Weight: 7.0kgs (Each one) Gross Weight:15.0kgs (One pair)
Packing Size: 606x373x291mm
Speaker Unit: Output Power: 15W(Max.:30W)
Frequency response: 55Hz~20KHz
Separation: 86dB Impedance: 4 ohmsHT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Dont like those? How about these...HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
And the specs...
Pure Vacuum Tube Amplifier (Tube Model: 6L6G x 2 ECF82/6F2 x 1/Each one)
Amplifier: Output Power: 20W/Each(Max.:25W)
Frequency response:20Hz~50KHz(1w Output) 30Hz~30KHz(15w Output)
S/N: 87.5dB(A-Weight)
Net Weight: 9.0kgs(Each one)
Gross Weight: 20.0kgs(One pair)
Packing Size: 530x490x395mm
Speaker Unit: Output Power: 30W(Max.:50W)
Frequency response: 50Hz~20KHz
Separation: 87.5Db
Impedance: 8 ohmsHT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Now all you tube heads -- I'm taking pre-orders for these speakers if you wanna have a truly complete "all tube" 2-channel system. I'll give you a great deal on 'em. I accept cash, checks and money orders.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Powered speakers, not exactly a new idea.
Cheers,
Cheers,
Russ
True......but with tubes? I have heard of solid state self powered but tubes is a first for me."Its worked so far but we're not out yet."
"Hey big man let me hold a dollar" -
Yeah, they are out of China, first showed up about 18months-2years ago - apparently SOMEONE is buying them, or they wouldn't still be around.
Cheers,
